04-28-2020 02:51 PM
Hello, I am on packet tracker trying to activate "UCK9" and it is not working. All I am able to activate is the "
securityk9". When I see all the available license in my routers, thats what I get.
Router#show license feature
Feature name Enforcement Evaluation Subscription Enabled RightToUse
hseck9 yes no no no no
AdvUCSuiteK9 yes yes no no yes
FoundationSuiteK9 yes yes no no yes
appxk9 yes yes no no yes
cme-srst yes yes no no yes
ipbasek9 no no no yes no
securityk9 yes yes no yes yes
throughput yes yes no no yes
uck9 yes yes no no yes
internal_service yes no no no no
THANK YOU!
04-28-2020 04:38 PM
hi,
what error you are getting ?
04-28-2020 06:48 PM
that the command doesn’t exit! The only “license” I can activate is the “securityk9”.
04-28-2020 07:56 PM - edited 04-28-2020 07:59 PM
can you active by using:
on exec mode
license right-to-use move uck9
-- accept the license agreement
license right-to-use move cme-srst
config terminal
license boot level uck9
license boot level cme-srst
exit
wr mem
you may need to restart your router if it didnt enabled
04-28-2020 08:39 PM
04-28-2020 09:18 PM
04-28-2020 10:28 PM
you need to do it in exec mode/enable mode.
Router>enable
Router# license right-to-use move uck9
04-29-2020 05:37 AM
04-29-2020 04:02 PM - edited 04-29-2020 04:06 PM
i am not sure why it didn't worked on ur ISR but this is how we activate licenses on our I'SRs. Please share snapshot again
i am attaching snapshot of supported Routers for CUCME with platform capacity support.
Ref:
04-29-2020 05:15 PM
Here is the screenshot. Thank you
