Help a n00b with ASA 5505 configuration.
mealyman
I recently took over a client with an ASA 5505 ver. 8.2 device and need some help configuring, as I'm unfamiliar.  I've done as much Google-fu as I could, and came up with these rules, but here is the situation:
Client has an ISP supplied modem/router in BRIDGE mode w/ (1) static IP to the ASA 5505.  There is one internal network segment 192.168.1.x, and one DMZ 192.168.2.x.  The machine on the DMZ needs FTP access from the outside, and complete access from inside.
I know this is a relatively simple configuration, but as a "freshman" in this area (mostly a developer), I figured I'd ask advice!
Anyway:
green = inside
red = outside
orange = DMZ
nat (green) 1 192.168.1.0 255.255.255.0
nat (orange) 1 192.168.2.0 255.255.255.0
global (red) 1 75.131.x.x interface
access-list DMZ permit ip host 192.168.2.1 192.168.1.0 255.255.255.0
**allow IP traffic from FTP server to internal subnet
access-list DMZ deny ip any any
access-list INTERNAL permit tcp any host 192.168.2.1 eq 21
**users inside can access FTP server
access-list INTERNAL permit ip 192.168.1.0 255.255.255.0 any
**users inside can access any other network
access-list INTERNAL permit ip 192.168.1.0 255.255.255.0 75.131.x.x 255.255.255.252
**users inside can access external interface
access-list INTERNAL deny ip any any
access-list EXTERNAL permit tcp any 75.131.x.x eq 21
**permit any host on the outside to access the FTP server
access-list EXTERNAL deny ip any any
Thanks for any advice you can provide.
Terence Payet
For this you will need static PAT.
Based on the snipet config, you only have one public ip which is currently configured on the outside interface.
Config will as follows:
static (inside,outside) tcp 75.131.x.x 21 192.168.2.x 21 netmask  255.255.255.255
The 75.131.x.x represent your public ip address
The 192.168.2.x represent your ftp server
HTH.
Please rate helpful post.
Terence
Okay, I think I figured out what you're trying to say...I'll attempt it in a little bit after hours and see how things go!
