Help configurating an 851 with PPPoE and DHCP
paltinis2
I write this because i'm puzzling myself for a few days now trying to find a way to configure my 851 for home use.
My internet provider use PPPoE with PAP and althrough I found many configuration options they all are incomplete...or i cant find the logic behind those commands.
First of all I need to say what I need:
1. Configurate my int Fa4 (WAN) with pppoe so when i insert my ISP cable in it it will negotiate and take IP.
2. Configurate DHCP on LAN (Fa0-3) so that when I insert my PC it will take a fake IP.
Here is the place where i found some conf examples: http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/pppoenat.html and I have some questions:
1. MTU - Should I use the 1492 value or the "pppoe-client ppp-max-payload 1500"?
2. ip route 10.10.25.2 255.255.255.255 dialer 0 - How can i set an IP route when my connexion informations only come after i connect? (Because is PPPoE)???
3. I cant configurate the DHCP because I dont know the default route, I dont know the DNS, and i dont know the default gateway because I dont know them due to PPPoE !!!
Please help me because I dont know what to do whit it.
Thank you
20 Replies 20
ip subnet-zero
no ip routing    change it to ip routing
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.10
interface Dialer0
ip address negotiated
ip mtu 1492                                            You're missing the ip nat outside command
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap
ppp pap sent-username ************ password **************!
Regards.
Alain.
I have repaired that Cadet Alain earlyer with the help of Mr. Peter Paluch who posted me the cfg commands, but i still forgot something . I really do appologise for my stuborness but i'm kinda new with the Cisco configurations,but I want to learn because is really nice, I like it!
Tank you
Now i'm closer than ever, the DHCP is working, and even the led for PPP is now on, but something still dosent tie up, maybe is because i missed that command.
I'm trying to use this running config to a 851 router but i get an error to this line:
Paltinis(config)#no ip dhcp use vrf connected
% Invalid input detected at '^' marker.
and the confir dose not work.
Here is my running config someone can helpme to see what i do wrong.
Thank you.
Paltinis#sh running-config
Building configuration...
Current configuration : 1654 bytes
version 12.4
no service pad
hostname Paltinis
boot-start-marker
boot-end-marker
enable secret 5 $1$T/5A$rNrZUOri4.JHzFBb7vB.21
enable password admins
no aaa new-model
dot11 syslog
no ip dhcp use class
ip dhcp pool LAN-Palt
   import all
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   lease infinite
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username admin password 0 admin
archive
log config
  hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username ************* password ***************
ppp ipcp dns request accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password admin
login
scheduler max-task-time 5000
end
Paltinis#
I have found out this post
http://808techblog.com/netflow/2008/02/ saying that there is a problem in diffrent software versions. I checked and my router has Version 12.4(15)T6. Please tell me if i need to make downgrade in order to work.
Hello Adrian,
I do not think you need to downgrade your IOS version. Also, those two lines (no ip dhcp use class and no ip dhcp use vrf connected) can be ignored and skipped, as they are not important for your basic setup. The configuration should work nicely without these two lines.
So what exactly does not work for you?
Best regards,
Peter
P.S.: It would be more appropriate to create a new, separate thread for your issue, instead of discussing this in an existing thread.
  Thanks for your reply, I did opend a new thread here:
https://supportforums.cisco.com/message/3889331#3889331 and I got it working now. It looks like it was the Int Fa4 disabled...:) I was prepared to downgrade it to an older version but than Mr. Richard Burts  told me to check the interface.
Thank you again for the reply.
