Help configuring LTE 4G on Cisco C887VAG-4G-GA-K9
bsgd
Hello all,
First of all let me tell you that Im am completely new to Cisco products and this is the first time I am trying to configure a Cisco product. I run an small business and have just bought a brand new LTE router.
I have the SIM card in and after accessing the default router address 10.10.10.1 I started the QUICK SETUP WIZARD. I just let everything set at default, but at the end, when I click the SUBMIT button, an error comes up saying: "Invalid input detected. Command: dialer string"
Below is the automatically generated CLI that I get when I click CLI PREVIEW.
I do have the knowledge to configure regular household routers, but this Cisco seems like a whole different beast, so I need some step by step help. All I want to do is get internet from my 4G provider, and thats all.
Thanks everyone and sorry if I am missing something obivous. I did try going into advance configuration mode and trying to check the 4G LTE interface as MAIN WAN INTERFACE but a message saying "APPLYING" pops up and never finishes, I have to close Chrome and restart all over.
hostname Cisco
ip domain name regence
clock timezone GMT -3
ip dhcp pool ccp-pool
dns-server 10.10.10.1
exit
ip dns server
ip dns view default
default dns forwarder
default dns forwarding
default domain lookup
default domain name-server
interface Vlan1
ip nat inside
exit
object-group network local_lan_subnets
10.10.10.0 255.255.255.128
ip access-list extended nat-list
permit ip object-group local_lan_subnets any
deny ip any any
default interface Cellular 0
no chat-script lte
chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK"
interface Dialer1
description PrimaryWANDesc___Cellular0
encapsulation slip
ip nat outside
ip address negotiated
dialer pool 1
dialer-group 1
dialer persistent
dialer string
dialer idle-timeout 0
no shut
exit
no shut
load-interval 30
dialer in-band
no peer default ip address
dialer pool-member 1
async mode interactive
ip nat outside
exit
line 3
script dialer
modem InOut
no exec
transport input all
transport output all
ip forward-protocol nd
dialer-list 1 protocol ip permit
access-list 23 permit 10.10.10.0 0.0.0.127
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list nat-list interface Dialer1 overload
26 Replies 26
No, I had only one SIM in slot 0.
Im away from the router now but will post back the requested info in a few hours with a second SIM inserted in slot 1.
Thanks again, you've been very helpful.
Sorry for the delay, I have been out of town for a few days but will be back tonight and get both sims in the router.
Just wanted to let you know why I still havent posted back :)
Thanks.
Hello Georg,
I have just reconnected my router, and it looks like after been off for a few days it lost all config, and I had to do it all over again!
Is this excpected to happen? I dont think so, and Im kinda worried since this is a brand new router.
did you issue the command below:
877#copy run start
This will save your running config to a file called startup config, which is permanently stored in your router memory...
No, I didnt. I only used the WR MEM command as suggested.
What is the difference between the two?
I just got myself a C881W (to use as an access point along with the C887 for WI-FI) and I am having a very hard time getting it running too, even after trying to follow the steps at http://bogomip.net/blog/configuring-a-cisco-881w/
wr mem and copy run start should in theory do the same thing...not sure what went wrong. Try and issue both commands, then do a 'show startup-config' to check if the startup file matches what you have configured.
Regarding the 881W, how is that connected to the 887 ? Post the config of the 881W you have so far...
OK, So I will retry using both commands on the 887. I'm just setting up both routers on my bench now so I can try to get them going and talk to each other. All I need is to have a WI-FI network with internat access from my LTE SIM card. I have been using regular routers for this, but the are very unrealible,and thats why Im now trying to get something a little better.
The 881W FE LAN 0 port is directly connected to the 887 FE LAN 0 port. Right now its back to factory since after following all the step by step commands llisted at http://bogomip.net/blog/configuring-a-cisco-881w/ I ALWAYS end up loosing connection to the router (by TELNET) after issuing these commands:
interface FastEthernet0
switchport mode trunk
exit
After that its just plain impossible to reconnect at any address and I have to restart all over after a factory reset. Maybe I sould try using the controller to serial cable and a USB to serial adapter? No sure.
These Cisco routers are pretty complex to configure and debug when something goes wrong.
if you initially set up the routers, better use the console port and a terminal emulator such as Putty, that way, you won't lose connectivity if you misconfigure something...
Thanks again Georg for all the help.
OK, so now Im focusing on the 881W to try to make internet available through WI-FI. I have factory reset it once more and connected it using a serial to USB adapter and Putty. I get the window below, but it wont accept 'regular' commands as before (whe I was using telnet).
I just get a Router> prompt, but typing CONFIGURE TERMINAL gives me an error.... please see attached pic.error881w.JPG
You need to be in exec mode. Type:
Router>enable
Then enter the password (default is admin or cisco)
Thanks, I will stay up late tonight and try to configure it myself using the tutorials I found online.
Will post back tomorrow how it went :)
So, I have been reading a lot and managed to get internet through wi-fi using my C887 and Cisco881W. I have managed to enable WPA2 and setup my SSID on my CISCO881W. But I still have a few questions:
1- Im a little confused on how to correctly set the routers up. My C887 has DHCP enabled and my Cisco881W also. At first I thought they would not work like these but they do. Why?
2- Is there a way to download the COMPLETE router config so if anything happens I can just reaload a file using some command and get everything working again?
Thanks again :)
