Can't add redistribute under VRF
Mustain
Hi Everyone,
On my Catalyst 9500 I can't add redistribute ISIS on router bgp after address family ipv4 vrf ABC, the error was like this below
redistribute isis level-1-2 route-map BLOCK-TAG
%VRF specified does not match this router
Anyone know what this happen?
Harold Ritter
The isis process is not configured as a vrf instance. You need to add "vrf ABC" under the router isis instance as follow.
router isis
vrf ABC
Deepak Kumar
I didn't verify on a router or lab but the issue: %VRF specified does not match this router" I was faced with OSPF because of forgot to configured OSPF instance with vrf keyword.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Harold Ritter
router isis
vrf ABC
Hi Harold,
I just following the deployment guide for SDA, and in the ISIS configuration section they not configure vrf instance under router ISIS.
