Help configuring WAN connection between two Cisco 2911 routers
Clay Plaga
Level 3
Level 3
I have two Cisco 2911 routers on my test Network. I would like to make a Wan connection between the two routers that would closely simulate a real-world configuration. What configuration can I make to connect the two Cisco 2911's with a WAN connection? I have made a T1 cross over cable.
Thank you.
2 Accepted Solutions
I assume your routers have WIC-1DSU/WIC-1DSU-V2 cards installed?
Have a look at the link below:
Cisco Router — T1 Back-to-Back
https://packetu.com/2014/05/12/cisco-router-t1-back-back/
that should work...
7 Replies 7
Thank you for the information. I found this post on the Cisco other routing forum:
https://community.cisco.com/t5/routing/connecting-2-routers-with-only-fastethernet/td-p/2254629
I connected the two 2911's using gi0/2 on both routers, then used the configuration in the forum post and it worked. I then made static routes for the vlans on both routers, and I got connectivity to the vlans. Only a straight through cable between the routers worked. I still have my original question. If I wanted to connect a router at a main office to another router at a branch office, ten blocks away, how would that be configured in the real world.
Thanks.
if you have a remote branch office, in the 'real' world, you would have different options, depending on what your local ISP(s) offer: Metro Ethernet, MPLS, SD-WAN, (DM)VPN...there are numerous possibilities.
A T1 using WIC-1DSUs is such an old technique, I don't even know if it is used anymore. A T1 has a speed of 1,5MB, which obviously is very low speed.
I have a Cisco VWIC3-2MFT-T1/E1 card in both 2911 routers. Can I connect the cards together with T1 crossover to simulate a WAN connection?
Thank You.
that should work...
 Is there a configuration I need to make on the VWIC3-2MFT-T1/E1 cards?
Thank you.
have a look at the link below. It is not the exact config, leave out the voice support...
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/vd-t1e1_vwic3.html#73239
