Connecting third-party AP to Cisco 897 ISR
RokasK
Hello
I can't get my MikroTik access point route to internet. It looks like I can ping internet from ap itself and clients connects to it via DHCP but I suspect something is wrong with ISR configuration.
which IP address do the clients connected to the Mikrotik AP have ? Make sure the IP addresses are included in the access list used for NAT on the ISR.
The access list you currently use has the wrong wildcard mask. You are also missing a static default route. Make the changes marked in bold:
Current configuration : 5234 bytes
! Last configuration change at 17:36:51 UTC Sat Apr 3 2021 by noname
version 15.5
hostname cisco_isr
boot-start-marker
boot config usbflash0:CVO-BOOT.CFG
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$wyMt$1Di1CSiiQTzThkCvExLLl0
no aaa new-model
ethernet lmi ce
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.10.5
ip dhcp excluded-address 10.10.10.3
ip dhcp pool cvo-pool
import all
network 10.10.10.0 255.255.255.224
default-router 10.10.10.1
lease 0 2
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip name-server 1.1.1.1
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C897VAG-LTE-GA-K9 sn FCZ194393LQ
vtp mode transparent
username cisco privilege 15 secret 5 $1$lzEQ$iESwCjupCP1rWoLZh4GLi/
username noname privilege 15 secret 5 $1$/gNb$r3Rs2Dhf0v6U1JpfAENv20
controller VDSL 0
controller Cellular 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
no cdp run
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Cellular0
no ip address
encapsulation slip
shutdown
dialer in-band
dialer string lte
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
interface GigabitEthernet0
no ip address
spanning-tree portfast
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
duplex full
speed 1000
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
description $ES_WAN$$FW_OUTSIDE$
no ip dhcp client request tftp-server-address
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip inspect DEFAULT100 out
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.224
ip access-group 100 in
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet8 overload
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 overload
--> access-list 1 permit 10.10.10.0 0.0.0.31
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
version 15.5
hostname cisco_isr
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
import all
lease 0 2
ip cef
no ipv6 cef
controller VDSL 0
no cdp run
interface ATM0
no ip address
shutdown
interface Cellular0
no ip address
encapsulation slip
shutdown
dialer in-band
dialer string lte
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
duplex full
speed 1000
no ip address
no ip address
no ip address
no ip address
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
media-type rj45
interface Vlan1
ip nat inside
ip http server
control-plane
line con 0
login local
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
RokasK
Thank you for your quick reply I use DHCP range of 10.10.10.15-10.10.10.30 on MikroTik
and when I try to set default route
cisco_isr(config)#ip route 0.0.0.0 0.0.0.0 gi8 overload
% Invalid input detected at '^' marker.
whether its in config or in if-config mode
sorry, my mistake, that has to be:
cisco_isr(config)#ip route 0.0.0.0 0.0.0.0 gi8 dhcp
The access list should be:
access-list 1 permit 10.0.0.0 0.255.255.255
