help connecting vlans with 3 routers
NinjaTurtle2021
hi I tried so many things like router rip, ip route etc but I cannot connect my vlans altogether
it seems only vlans 10,20,30,40,50 communicate but not 60 70 80
my architecture looks like this
SW1 (with vlans 10,20) ---- R1 ---- SW3 (with vlans 40,50) ---- R2 ---- R3 ---- SW4(with vlans 60,70,80)
 SW2 (with vlan 30)
can someone please help me
basically, you had the wrong IP addresses on some of the interfaces connecting the routers to each other. You also had all subinterfaces for all Vlans configured on both routers, Router0 and Router2. Find attached the revised version. I have saved this in PT version 7.3.0, if you cannot open it, below are the router configs:
Router0#sh run
Building configuration...
Current configuration : 1346 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router0
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
description vlan 10
encapsulation dot1Q 10
ip address 10.0.10.14 255.255.255.240
interface FastEthernet0/0.20
description vlan 20
encapsulation dot1Q 20
ip address 172.16.20.6 255.255.255.248
interface FastEthernet0/0.30
description vlan 30
encapsulation dot1Q 30
ip address 192.168.30.30 255.255.255.224
interface FastEthernet0/1
ip address 128.0.0.3 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1.40
description vlan 40
encapsulation dot1Q 40
ip address 10.0.40.14 255.255.255.240
interface FastEthernet0/1.50
description vlan 50
encapsulation dot1Q 50
ip address 172.16.50.6 255.255.255.248
interface Vlan1
no ip address
shutdown
router rip
version 2
network 10.0.0.0
network 128.0.0.0
network 172.16.0.0
network 192.168.30.0
network 192.168.60.0
default-information originate
no auto-summary
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Router1#sh run
Current configuration : 655 bytes
version 12.4
hostname Router1
ip cef
no ipv6 cef
ip address 128.0.0.1 255.255.255.0
duplex auto
speed auto
ip address 129.0.0.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router rip
version 2
network 128.0.0.0
network 129.0.0.0
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router2#sh run
Current configuration : 1116 bytes
version 12.4
hostname Router2
no ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
interface FastEthernet0/0.60
description vlan 60
encapsulation dot1Q 60
ip address 192.168.60.6 255.255.255.248
interface FastEthernet0/0.70
description vlan 70
encapsulation dot1Q 70
ip address 10.0.70.6 255.255.255.248
interface FastEthernet0/0.80
description vlan 80
encapsulation dot1Q 80
ip address 172.16.80.6 255.255.255.248
ip address 129.0.0.2 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router rip
version 2
network 10.0.0.0
network 129.0.0.0
network 172.16.0.0
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
7 Replies 7
post the running configuration of switch 4...
Richard Burts
You give a brief description of the topology, which vlans communicate and which do not, and a diagram. But there is no detail of what you have configured and no other information to help us identify the issue. As a start can you post the output of show ip route from SW4, R3, R2, and SW3. Also please give us the IP subnet associated with each one of the vlans.
Rick
Rick
hi sirs thanks for replying
I'd like to give you my .pkt file to show you the configuration but it seems I cannot attach it to my reply.
anyway thanks a lot for replying
you need to zip the .pkt file, then you can attach and upload it...
thanks sir
here you are
Router0#sh run
version 12.4
hostname Router0
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
description vlan 10
description vlan 20
description vlan 30
duplex auto
speed auto
description vlan 40
description vlan 50
interface Vlan1
no ip address
shutdown
router rip
version 2
network 10.0.0.0
network 128.0.0.0
network 172.16.0.0
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router1#sh run
version 12.4
hostname Router1
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router rip
version 2
network 128.0.0.0
network 129.0.0.0
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router2#sh run
version 12.4
hostname Router2
no ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
description vlan 60
description vlan 70
description vlan 80
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router rip
version 2
network 10.0.0.0
network 129.0.0.0
network 172.16.0.0
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Hi sir it eventually works
thank you so much sir and have a nice day :)
