Help Me With Basic Understanding of WICs and T1
moneer.rifai
So I am tasked with a simple project: get a remote site talking to our main site. It is point to point T1. The provider said it will be on "fiber but handed back as copper", whatever that means. I don't believe it is ethernet. I have a Cat 5 cable that runs back to the server room from the DMARC and that is supposedly my handoff.
See the attached image for a basic network diagram.
I am a little confused about the WICs.
Router 1 (2801) has the following: WIC 1 DSU-T1 V2
VWIC 2MFT-T1 (two of those WICs)
Router 2 (2600) has the following: WIC 1DSU T1
VWIC 1MFT-T1
Correct if I am wrong, but I will only be using the T1 DSU/CSU port.
Also, does anyone have a basic guideline for what needs to be configured to get the two routers talking? Do I need to worry about the other WICs with the CTRLR ports? Is clocking configure on the T1 DSU/CSU port?
Any links or hints or info will be greatly appreciated.
paolo bevilacqua
You can use either type of cards. I think you will have to configure internal clock one side.
Other than that, there is plenty of documents and threads on how to configure a T1 for data.
vmiller
Level 7
Level 7
Here is a jumpstart for your search:
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800b1501.shtml
Your copper handoff will be RJ-48.
There are links on the page listed that will take you into other module spec sheets.
http://www.cisco.com/en/US/docs/ios/12_2/interface/configuration/guide/icfserin.html
Basic serial interface configuration for IOS.
