How to bridge T1 line with Serial Leased Line
alexlim1984
We have a setup which really need the Cisco Expert guys' advices.
We have 2 Cisco Router, with Voice DSP modules cards, and the T1/E1 Interfaces, and smart serial interface. We will install 1 unit at each site, and every site already have 1 leased line ready.
The scenario we trying to achieve is that we want to have a logical connection to connect T1/E1 connection to both sites, by using the leased line.
Is that possible?
14 Replies 14
vmiller
Level 7
Level 7
Your question is a bit ambiguous.
If you have leased lines at both locations, its not too difficult to connect things.
     a. where do the leased lines terminate ? at the other locations?
     b. What kinkd of leased line ? T/1 or E/1?
you can start by digging in here:
http://www.cisco.com/en/US/docs/ios/12_2/interface/configuration/guide/icfserin.html
paolo bevilacqua
Yes, it possible. But if you will attempt do-it-yourself, it will be  difficut for yout to deliver sure and consistenat resutls.
You should hire an UC Certifies Cisco partner, or reputable consultant of equivalent experience instead.
Hi Guys,
The scenario is such as below. There are 2 site of equipment that will be connecting to Cisco Router via the E1/T1 interfaces, each at site A and site B.
What we are trying to achieve is to "brigde" the incoming Leased Line connection to the E1, so that Customer Device at Site A can have logical E1/T1 connection to Customer Device at Site B.
Appreciate if anyone can offer a sample configuration, or expert advics on this. Millions Thanks !!
What exactly is the  customer device ? The proper solution depends on that.
Customer devices should be Avaya Devices, with E1 interfaces to cater for voice call functions.
Just wondering how to configure the Serial Interface, and "bridge" it to both E1 and LAN ports. Or if you guys have any others great ideas, it would be fantastic !!
Appreciate your helping hand! Really bumping my heads against the walls now ...
You will use VWIC cards and PVDM modules to connect the PBX with VoIP.
Please remember to rate useful posts clicking on the stars below.
Hi, Paolo,
Any possibility if you have any sample configuration for this? or some guidelines?
The Cisco Router we have is installed with VWIC cards and PVDM modules.
Thanks.
The best configuration examples are in the Cisco documention.
Again, if you are serious about this and want professional results, do not try DIY, hire instead someone with experience.
Thank you for the nice rating and good luck!
One of the site will be using LongReach IR+ http://www.longreachwireless.net/index.php?option=com_content&view=article&id=42&Itemid=28, and the other will be using http://www.motorola.com/Business/XU-EN/Product+Lines/Dimetra+TETRA/TETRA+Infrastructure/MTS4__XU-EN_PK-EN_XF-EN.
Both are to be connected to the Cisco Router E1 interfaces, using PRI-Group on E1 interface. Anyone does this integration before?
Million Thanks !!
Some updates. The network (leased line) is actually layer 2, and we have configure site A router BVI of 10.10.7.1, and site B router BVI as 10.10.5.1. Both can ping to each others without any problems.
For the bridging, we have also bridge the serial interface and the LAN interface at both router, so now we need to also bridge their E1 interface, so that their end devices can have logical connection to each others, such as below setup.
CPE 1 --- E1--- Cisco 2911 ----- Serial -------------> Leased Line <---------- Serial ----- Cisco 2911 ---- E1 ---- CPE2.
I have get a E1 interface running, and configure the timeslots accordingly. However, both the serial 0/0/0:X is showing LINE UP, PROTOCOL DOWN.
Can someone share any info on this? Hereby I upload the configuration file of both router.
Site A
ter len 0
BukitBauk#
BukitBauk#
BukitBauk#sh run
Building configuration...
Current configuration : 1983 bytes
! Last configuration change at 13:01:30 UTC Mon Sep 24 2012
! NVRAM config last updated at 12:39:08 UTC Mon Sep 24 2012
version 15.1
hostname BukitBauk
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
ip source-route
no ip routing
no ip cef
isdn switch-type primary-4ess
voice-card 0
license udi pid CISCO2911/K9 sn FGL1626107C
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
clock source internal
channel-group 0 timeslots 1-5
bridge irb
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet0/0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
ip unnumbered BVI1
interface Serial0/1/0
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.10.5.1 255.255.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login
transport input all
line vty 5 15
password cisco
login
transport input all
scheduler allocate 20000 1000
end
BukitBauk#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
BukitBauk uptime is 6 hours, 46 minutes
System restarted at 06:15:38 UTC Mon Sep 24 2012
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FGL1626107C
3 Gigabit Ethernet interfaces
1 Serial interface
1 Serial(sync/async) interface
1 terminal line
1 Channelized E1/PRI port
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#      PID            SN
*0        CISCO2911/K9          FGL1626107C
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
BukitBauk#
BukitBauk#
BukitBauk#
BukitBauk#siw         show int 0/0/0:0
% Invalid input detected at '^' marker.
BukitBauk#
BukitBauk#show int s0/0/0:0
Serial0/0/0:0 is up, line protocol is down
  Hardware is DSX1
  Interface is unnumbered. Using address of BVI1 (10.10.5.1)
  MTU 1500 bytes, BW 320 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:06, output hang never
  Last clearing of "show interface" counters 00:15:13
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 240 kilobits/sec
     913 packets input, 12782 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     91 packets output, 2184 bytes, 0 underruns
     0 output errors, 0 collisions, 31 interface resets
     913 unknown protocol drops
     0 carrier transitions
  Timeslot(s) Used:1-5, SCC: 0, Transmitter delay is 0 flags
BukitBauk#
BukitBauk#
BukitBauk#
BukitBauk#show int             ver
BukitBauk uptime is 6 hours, 47 minutes
export@cisco.com.
1 Serial interface
1 terminal line
License Info:
License UDI:
Device#      PID            SN
data          None          None           None
BukitBauk#
BukitBauk#
BukitBauk#
BukitBauk#show controller e1
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
  Data in current interval (480 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 2 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
BukitBauk#
Site B
BukitKemuning#
BukitKemuning#ter len 0
BukitKemuning#
BukitKemuning#
BukitKemuning#sh run
Current configuration : 2051 bytes
! Last configuration change at 12:44:59 UTC Mon Sep 24 2012
! NVRAM config last updated at 12:38:58 UTC Mon Sep 24 2012
version 15.1
hostname BukitKemuning
boot-start-marker
boot system flash0:/c2900-universalk9-mz.SPA.151-4.M4.bin
boot-end-marker
card type e1 0 0
no aaa new-model
no ipv6 cef
ip source-route
no ip routing
no ip cef
voice-card 0
license udi pid CISCO2911/K9 sn FGL1626107D
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
bridge irb
no ip address
no ip route-cache
shutdown
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
ip unnumbered BVI1
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.10.7.1 255.255.0.0
no ip http server
control-plane
bridge 1 route ip
gatekeeper
shutdown
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
password cisco
login
transport input all
line vty 5 15
password cisco
login
transport input all
end
BukitKemuning#
BukitKemuning#
BukitKemuning#
BukitKemuning#sh ver
BukitKemuning uptime is 5 hours, 3 minutes
System restarted at 07:58:43 UTC Mon Sep 24 2012
System image file is "flash0:/c2900-universalk9-mz.SPA.151-4.M4.bin"
export@cisco.com.
Processor board ID FGL1626107D
1 Serial interface
1 terminal line
License Info:
License UDI:
Device#      PID            SN
*0        CISCO2911/K9          FGL1626107D
data          None          None           None
BukitKemuning#
BukitKemuning#
BukitKemuning#
BukitKemuning#show int s0/0/0:0
  Hardware is DSX1
  Interface is unnumbered. Using address of BVI1 (10.10.7.1)
  Last input 00:00:00, output 00:00:07, output hang never
  Last clearing of "show interface" counters 00:15:03
     2995 packets input, 41930 bytes, 0 no buffer
     90 packets output, 2160 bytes, 0 underruns
     0 output errors, 0 collisions, 30 interface resets
     2995 unknown protocol drops
BukitKemuning#
BukitKemuning#
BukitKemuning#
BukitKemuning#show ver
BukitKemuning uptime is 5 hours, 4 minutes
export@cisco.com.
1 Serial interface
1 terminal line
License Info:
License UDI:
Device#      PID            SN
data          None          None           None
BukitKemuning#
BukitKemuning#
BukitKemuning#
BukitKemuning#show controller e1
E1 0/0/0 is up.
  No alarms detected.
  Data in current interval (493 seconds elapsed):
BukitKemuning#
BukitKemuning#
BukitKemuning#
BukitKemuning#
BukitKemuning#
Hi guys,
any updates?
we just need to make sure that all interfaces are bridge to the leased line interface to provide layer 2 connectivity for lan port and the e1 ports as well.
please help on advice.
As indicated before: you have to configure you must use VoIP, not bridging.
And if you want sure and quick results, hire a reputable consultant.
Hi Paolo,
Just an update. We don't need to setup the voice calls by using the Cisco Router.
What we need to do is that we would need to "somehow" connect from the Cisco E1 interface to CPE E1 interface. Once we issues the command "Channel-group 0 timeslots 1-5", we have the serial 0/0/0:0 interface created.
So, at the serial 0/0/0:0 interface, we bridge the interface to serial interface (from leased line) by using the "bridge-group 1" command. However, the Serial0/0/0:0 is up, line protocol is down.  Any ideas how to get the issues troubleshooted?
BukitBauk#show int se0/0/0:0
  Hardware is DSX1
  Last input 00:00:00, output 00:00:01, output hang never
  Last clearing of "show interface" counters 00:26:35
     1595 packets input, 22330 bytes, 0 no buffer
     160 packets output, 3840 bytes, 0 underruns
     0 output errors, 0 collisions, 53 interface resets
     1595 unknown protocol drops
            You have to look at both routers, and make sure the configuration matches.
Note, you will have bad resutls using bridging, you must use routing.
