Help needed with Cisco 4221/K9
Cisco7777
Hello to all community,NETWORK 1.pngAbove is a diagram of my network, we had Zywall network device then upgraded to CISCO 4221/K9, internet is working fine, but the IP Phones does not, we are using Cloud phone service, so the problem with the Router, kindly check configuration of the router below:
Router(config)#do s
Current configuration : 1752 bytes
! Last configuration change at 04:37:06 UTC Wed Jan 22 2020
version 16.5
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
no shell processing
no aaa new-model
ip dhcp excluded-address 192.168.2.1
ip dhcp pool LAN_POOL
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8 8.8.4.4
lease 200
class 1
address range 192.168.2.100 192.168.2.240
ip dhcp class 1
ip dhcp global-options
dns-server 77.232.5.12 77.250.1.15
subscriber templating
diagnostic bootup level minimal
redundancy
mode none
interface GigabitEthernet0/0/0
ip address 77.162.22.201 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
negotiation auto
threat-visibility
ip default-gateway 77.162.22.1
ip nat inside source static tcp 192.168.2.2 80 interface GigabitEthernet0/0/0 80
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 77.162.22.1
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
access-list 1 permit 192.0.0.0 0.255.255.255
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
login
no network-clock synchronization automatic
end
Router(config)#
Seb Rupik
