Help on EIGRP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-05-2009 12:11 PM - edited 03-04-2019 01:07 AM
I have five offices now i want to run eigrp between theses office..here z my rquiremnts
<br />
<br />A -- HQ
<br />192.168.1.0
<br />B - B0
<br />192.168.2.0
<br />C - B0
<br />192.168.3.0
<br />D - B0
<br />192.168.4.0
<br />E - B0
<br />192.168.5.0
<br />
<br />1) All branch office routes should prefer towards HQ only.
<br />
<br />D guy wants to communicate to A . it should not come via D-B-E-A. it should come D-A only.
<br />
<br />2) If D wants to communicate E. he sould come D-A-E
<br />
<br />What need to be on eigrp level and i need eigrp config at all locations if possible.
<br />
sateesh
- Labels:
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2009 01:10 PM
So basically it's a hub-and-spoke topology with HQ (A) in the center of the network. Is this correct?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2009 01:36 PM
yes..your are ryt.
sateesh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2009 01:34 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2009 02:03 PM
sateesh
It would help us to give you better advice if you would tell us some details about the topology of the network. You have told us that it is a hub and spoke, so we can assume that each spoke has a link connecting it to the hub. But do the spoke routers have any links connecting directly to other hubs?
From your description that spoke to spoke traffic should always go from spoke to hub to other spoke I would assume that there is no need for spoke to spoke links. But it would be helpful if you would tell us specifically what links connect things in your network.
If it is a simple hub and spoke network and each spoke connects only to the hub then the configuration can be easy. You would enable EIGRP on each router on all of the interfaces. In this situation the spoke routers only learn routes from the hub and your requirements are satisfied.
In this simple hub and spoke environment your config could be enhanced by configuring each spoke router as an EIGRP stub router. And the configuration could also be enhanced by configuring a distribute list on the hub router which permits the advertisement of only a default route to each spoke router. These steps are not necessary but they would simplify the operating environment of the spoke routers.
If it is not a simple hub and spoke environment and there are some links from spoke to spoke, you would need to specify to us how those links should work, since they seem to be contrary to your requirement that spoke router traffic should only be forwarded to the hub.
Rick
Rick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2009 02:44 PM
1- You will need to configure all routers as stub routers except the HQ.
2- All stub routers needs to learn the networks from the HQ besides a Default route.
3- you will need to disable (Split-Horizon) on the physical Interface IF all routers are connected to the same Physical Interface of the HQ's router.
By doing the above, U will make sure all routers (except the HQ) are not quered for Routes if changes occured in the Eigrp topology since all connectivity required through the HQ.
Disabling (Split-Horizon)shall make the router sends updates out the same interface they have been recieved on IF and Only If they are connected to the same Interface.
Mohamed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2009 03:07 PM
hi,
I am going to take VPLS connection between the offices. Now A is HQ.
All my office will connected to Service porvider(Pure L2) and full mesh connection.
sateesh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-06-2009 10:12 AM
Still awaiting for reply.
sateesh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2009 07:46 AM
Can anbody give the solution.
regards
sateesh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2009 01:49 PM
I have attched diagram for easy understand.
Service provider VPLS means think that point to point link full mesh between my locations.
option 1:
My communication should happen through HEADOFFICE only.
In future i may required comunication directly between Branchoffice also.
planning to run the EIGRP. pls provide the config for the same at all locations
sateesh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2009 01:56 PM
Sorry attach ment missed..pl. find the attached..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2009 02:18 PM
The VPLS service is a Point to multipoint in fashion. why ?? because the TTL of the labeled VC packet is always going 2 be 255 unlike the TTL of the VC label in l2VPN which is 2.
However, the VPLS can be configured in a point to point Scenario. with xconnect vfi command ..
All u have to do is to provide ur service provider with ur requirment and they should be able to set the HQ as Hub and all neighbors with their respective Virtual circuits. On the Spokes, they have to set ONLY asingle neighbor with the same Virtual circuit pointing to the HQ.
Mohamed
