Help Required to Improve the Network Architecture
Yasir Iqbal
Dear All,
I have attached our network architecture diagram. We are using inter-vlan routing for our ntework. DHCP pool for every Vlan is configure on core switch. Each aggregation switch using different VLAN. Some time network chok or hang due to broadcast generated from any where.
So please help me to improve the architecture using existing hardware.
Leo Laohoo
STP loop?
grabonlee
Level 4
Level 4
Yasir,
Network chokes on specific vlan or all vlans? Are you experiencing STP loop? Do you have any vlan extended across switches and what's your STP mode?
Dear,
Network chok on all vlan and we are using rstp.
Hello
Possible suggestions
Access-layer
Apply port security, storm control and stp portfast, bpduguard, to all edge ports
Manually prune vlans off the trunk interconnects for the vlans you don’t need to be advertised
Apply highest stp bridge ID for all vlans on each switch
Enable stp loopguard and UDLD
Apply dhcp snooping on the vlans that receive dhcp allocation, trusting any unplinks
Apply igmp snooping (if running multicasting)
Distribution layer
Manually prune vlans off the trunk interconnects for the vlan you don’t need to be advertised
Apply a high stp bridge ID for all vlans on each switch ( but lower value then access-layer switches)
Core
Make core switch STP root for all vlans
Enable pim BSR with core as RP (if running multicasting)
Kind Regards
Paul
