Help setting up new Cisco 2911 Router!
Jamie_ABSNet
OK, I'm fairly new to this, as my company just let our network admin go a while ago. Recently they bought a new Cisco 2911 router and told me that they want it connected to an outside WAN connection that they hadn't used in a while so they could create a little network on the side. They want to just plug the server into the router and go. Unfortunately, I am sort of clueless about how to set up the config for it.I know the show commands and some stuff about networking, but if someone could give me a hand thatd be great.
The outside gateway is xx.xx.xx.137
subnet is 255.255.255.248
There are 3 GE ports, with the line from the outside coming in on GE0/0. I've already activated the interface and it is up, but that's where I get stuck.
14 Replies 14
blau grana
Level 7
Level 7
Hi Jamie
This is basic config which you can use:
service password-encryption
hostname <>
logging buffered 128000
enable secret <>
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa session-id common
ip dhcp pool LAN_POOL
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
domain-name <>
dns-server <>
lease 0 8
ip cef
no ip domain-lookup
ip inspect alert-off
ip inspect max-incomplete low 500
ip inspect max-incomplete high 3000
ip inspect one-minute high 2000
ip inspect one-minute low 800
ip inspect tcp max-incomplete host 800 block-time 0
ip inspect tcp reassembly queue length 1024
ip inspect name INET_STATE-FW icmp
ip inspect name INET_STATE-FW dns
ip inspect name INET_STATE-FW ftp
ip inspect name INET_STATE-FW ntp
ip inspect name INET_STATE-FW tftp
ip inspect name INET_STATE-FW pptp
ip inspect name INET_STATE-FW echo
ip inspect name INET_STATE-FW udp
ip inspect name INET_STATE-FW tcp
username USER password PASSWORD
interface Gi0/0
description INTERNET_UPLINK
ip address X.X.X.X 255.255.255.248
ip access-group INTERNET_IN in
ip access-group BLOCK_PRIV_ADDRS out
ip nat outside
ip inspect INET_STATE-FW out
load-interval 30
duplex auto
speed auto
no cdp enable
no shut
interface Gi0/1
description LAN
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip verify unicast reverse-path
load-interval 30
no shut
no ip http server
no ip http secure-server
ip route 10.0.0.0 255.0.0.0 Null0 name DENY_RFC1918
ip route 172.16.0.0 255.240.0.0 Null0 name DENY_RFC1918
ip route 192.168.0.0 255.255.0.0 Null0 name DENY_RFC1918
ip route 0.0.0.0 0.0.0.0 X.X.X.137 name DEFAULT_ROUTE
ip nat inside source route-map RMAP-NAT interface Gi0/0 overload
ip access-list extended BLOCK_PRIV_ADDRS
deny   ip any 10.0.0.0 0.255.255.255
deny   ip any 172.16.0.0 0.15.255.255
deny   ip any 192.168.0.0 0.0.255.255
deny   ip 10.0.0.0 0.255.255.255 any
deny   ip 172.16.0.0 0.15.255.255 any
deny   ip 192.168.0.0 0.0.255.255 any
permit ip any any
ip access-list extended NAT_ACL
deny ip 192.168.0.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.0.0 0.0.0.255 any
deny ip any any
ip access-list extended INTERNET_IN
remark *** Allowed traffic ***
permit ip XYZ
remark *** Deny traffic not permited by IOS-statefull-firewall ***
deny   ip any any
ip access-list extended MGMT
permit ip X.X.X.X X.X.X.X any
deny ip any any
route-map RMAP-NAT
match ip address NAT_ACL
line con 0
exec-timeout 60 0
logging synchronous
line vty 0 4
exec-timeout 30 0
logging synchronous
access-class MGMT in
end
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
Just a couple of questions.
Do I put the Gateway address here, or just one of the 5 static IPs.
interface Gi0/0
Also
permit ip XYZ (What should go here for XYZ)
deny   ip any any
permit ip X.X.X.X X.X.X.X any (And here for X.X.X.X X.X.X.X)
deny ip any any
I really appreciate this.
Hi Jamie
In first post you wrote ->
I assume that ISP gave you some IP from /29 prefix, this ip address will be configured on Gi0/0 uplink interface, for example:
GW is 100.0.0.137 with subnet mask 255.255.255.248
it means network is 100.0.0.137/29 so one IP from range 100.0.0.138 - 100.0.0.142 will be configure on Gi0/0
[you should know which one IP was delegated to you by ISP, or entire range belongs to you?]
here you configure all IPs from which you would like to access router via telnet/ssh, if you will manage router only from local LAN, you will add this:
deny ip any any
deny   ip any any
This part is little bit tricky. You can move along two ways:
1) deny traffic which you do not want to allow and permit everything else
2) permit traffic which is desirable and deny everything else
First posibility is used when you do not know exactly what traffic will pass through routerm (common internet acces) but you know what you should deny (deny management access from public addresses and allow only some which you will use).
Second possibility is used when you know exactly what traffic will pass through router (some IPsec tunnels, connection to HQ,...) so you allow that traffic and deny everything else because entire traffic which is desirable is already allowed.
Best Regards
Ok, I believe I've got all of the info in the right places. Though there were a couple of errors I recieved when
applying the config to the router. I am getting an "Invalid input detected at '^' marker" under each one of the
"inspect" commands. Every other command went in ok.
hostname ABS2911RTR2
enable secret xxxxxxxxxxx
aaa new-model
domain-name xxxxxxx.com
dns-server xx.xx.xx.xx
lease 0 8
ip cef
no ip domain-lookup
interface Gi0/0
ip address xx.xx.16.138 255.255.255.248
ip nat outside
load-interval 30
duplex auto
speed auto
no cdp enable
no shut
interface Gi0/1
description LAN
ip address 192.168.3.1 255.255.255.0
ip nat inside
load-interval 30
no shut
no ip http server
ip route 0.0.0.0 0.0.0.0 67.216.16.137 name DEFAULT_ROUTE
permit ip any any
permit ip 192.168.3.0 0.0.0.255 any
deny ip any any
permit ip X.X.16.138 255.255.255.248 any
deny   ip any any
deny ip any any
route-map RMAP-NAT
line con 0
exec-timeout 60 0
logging synchronous
line vty 0 4
exec-timeout 30 0
logging synchronous
end
Hi Jamie
By ip inspect you will configure stateful firewall on your router, but it is not essential so you can ommit that.
Insted you can configure zone-based firewall or you do not have to configure any firewall, it is up to you.
Best Regards
Thank you very much, it's working now. One other question though. I was not able to RDP onto the server I have connected to the router. Could you tell me how to add that to the config? I thought it might have been under "
ip access-list extended NAT_ACL"  as permit tcp 192.168.3.246 eq 3389, but I wasn't sure.
Ting to RDP from LAN or Public.
Jawad
I'm outside the network. So I'm trying to RDP through the router I just set up. I can connect to the Internet just fine from the server.
Do a static NAT
ip nat inside source static tcp (RDP Server IP) 3389 (one Public IP form address Pool) 3389
*** Do Rate Helpful posts ***
Jawad
you need to do static port forward
in configuration mode:
# ip nat inside source static tcp SERVER_IP_ADDR SERVER_PORT int_Gi0/0_IP_ADDR OUTSIDE_PORT
in practice:
your WAN IP is 100.0.0.1
SERVER IP is 192.168.3.99
ip nat inside source static tcp 192.168.3.99 3389 100.0.0.1 22222
Now when you try to connect to server in your LAN from outside, use WAN IP 100.0.0.1 port 22222 (or one whatever you configure) and you will be forwarded to serve with ip 192.168.2.99 port 3389, only tcp protocol.
Also add this rule into allowed traffic so it will not be filtered
permit tcp any host 100.0.0.1 eq 22222
you can replace "any" with some network if you want restric access to RDP only on particular IPs.
Best Regards
Ok, I seem to have a problem. I was given an IP and such on the server, but cannot get anywhere but Google. I can search for things on Google, but I can't get to anything, the page just times out lol. I can't ping anything, and when I try and ping the IP from outside the network I get no response. I can ping the gateway from outside and inside I can ping the router. Any thoughts lol?
Could you post configuration of access list INTERNET_IN ?
Last time you post configuration, there was allowed only communication with some network /29, did you add something there? I think this would be the problem.
deny   ip any any
Best Regards
Good Morning,
All I did was change it so it would use the 192.168.2.0 range instead of the 3.0 range
permit ip 0.0.0.2 255.255.255.248 any (This keeps reverting back to 0.0.0.2, each time I reload the config)
permit tcp any host xx.xx.16.138 eq 3389
deny   ip any any
It should look like this;
permit ip xx.xx.16.138 255.255.255.248 any
deny   ip any any
**update**
I got the http up on the router so I could login to the web interface. I can ping the server, but I still can't ping anything outside the network including the gateway. Everything looks like it's set up correctly on CP Express.
Thank You!
I dont know what this even mean -> permit ip 0.0.0.2 255.255.255.248 any
Syntax of ACLs is:
0.0.0.0/8 is reserved range, I really do not know what did you trying to accomplish. Also wildcard mask has opposite meaning than network mask. It is written as f.e. 0.0.0.255 so first three zeros means that first three octets must be matched.
Here is document for some more info:
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml
Your WAN interface should be Gi0/0, delete ip access-group INTERNET_IN in from configuration of this interface, if everything wil be working than, you can be sure that problem is with ACL. Than modify ACL to your needs.
Best Regards
