IP Routing Issue
OfficeUser
Hi all,
I currently have a situation where my company has tills that point to an internal ip address but due to us outsourcing a particular function, require that ip address to route to an internet address. The address on the tills cannot be changed so we need to try something else. We currently have a Cisco 881 router but if we require a more advanced router, this could be organised.
Any ideas would be greatly appreciated
10 Replies 10
Ajay Raj
Your question is not clear, please elaborate.
Is there a way, through networking, to get it so when the tills point to the internal address, it forwards it on to the internet address and gets a response. I am quite new at networking so unsure if its possible?
You meant to say you want to access internet on particulare ip address..
Jawad
No, i need it so that if a till contacts 10.xxx.xxx.xxx it actually points to an static internet address we need to access
You can statically MAP That Internal ip to Public IP Address. So you will be to access it from PUblic too.
Jawad
Ok, how would i go about doing that?
Added in
Config Mode
route (config)# ip nat inside source static (local IP) (Public IP)
Like That
Jawad
Hmm, maybe i didnt describe it well, the public ip is actually a website that isnt owned by us as it is a suppliers one?
Doesnt nat just translate a local ip to a public ip which isnt what we need?
Its accessible from Internet or not.
Jawad
That command is working however I am not getting a response bkac,seems to go out fine but no response from the webpage that we need to access?
