Cisco 2921 - Dual WAN ISP failover
dbreveard1
I have a Cisco 2921 router with 3 ethernet interfaces. E0/0 is has just been setup to commuicate on secondary ISP.
E0/1 is configured as the interface that connects to my firewall.
E0/2 is setup as my default route and all traffic goest out this interface.
I'd like to be able to keep the traffic flowing out of interface e0/2, but make sure that when it fails traffic flows out of e0/0. Once the line has been restored, I'd like for traffic to be restored to the primary link. I have attached a copy of my running config to this email.
Building configuration...
Current configuration : 4860 bytes
hostname
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
no ip source-route
ip cef
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip name-server 4.2.2.2
username ***** privilege 15 secret * ******************************
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ISP Interface #2
ip address 192.x.x.195 255.255.x.x
ip access-group 100 in
ip access-group 100 out
duplex auto
speed auto
interface GigabitEthernet0/1
description ISP Interface #1
ip address 50.x.x.254 255.255.x.x
duplex auto
speed auto
interface GigabitEthernet0/2
description Inside WAN Interface
ip address 50.x.x.82 255.255.x.x
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
top 15
sort-by bytes
ip nat inside source list test interface GigabitEthernet0/2 overload
ip route 0.0.0.0 0.0.0.0 50.x.x.81
ip access-list extended test
permit ip 0.0.0.0 255.255.255.0 any
permit ip any any
access-list 100 permit ip any any
access-list 100 permit icmp any any echo
access-list 100 permit icmp any any echo-reply
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
blau grana
Level 7
Level 7
Best way to accomplish failover is to use dynamic routing protocol, I assume that you do not run any routing protocol with your ISP, so your only choice is using static routes.
Problem with static routes is that even if link is not working, interface status can stay up/up, so routing entry via that link will stay in routing table but all traffic will be blackholed.
I would suggest to use IP SLA with tracking, recently there were some threads with this issue so if you l you search in history, you will find some.
Basic config:
no ip route 0.0.0.0 0.0.0.0 50.x.x.81
ip sla 1
 icmp-echo 50.x.x.81
ip sla schedule 1 start-time now life forever
track 1 ip sla 2 state
ip route 0.0.0.0 0.0.0.0 50.x.x.81 track 1
ip route 0.0.0.0 0.0.0.0 192.x.x.19X 250
This will track if primary link is working, if not, default route via ISP2 is used.
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
  • Here is Sample Config
track 1 rtr 1
ip sla 1
icmp-echo (Next Hope IP of ISP1) source-interface interface GigabitEthernet0/1
ip sla schedule 1 life forever start-time now
track 2 rtr 2
ip sla 2
icmp-echo (Next Hope IP of ISP2) source-interface interface GigabitEthernet0/2
ip sla schedule 2 life forever start-time now
ip route 0.0.0.0.0 0.0.0.0 (Next Hope IP of ISP1) track 1
ip route 0.0.0.0.0 0.0.0.0 (Next Hope IP of ISP2) 2 track 2
ip nat inside source list test interface GigabitEthernet0/1 overload
**Do Rate All Helpful Posts**
Jawad
