Help understanding this NAT concept
Zahan Al-Rashid
I am going through the book and came accross question below:
Given the following partial ASA configuration, with all translation slots cleared, to
which address will host 10.0.0.101 be translated when initiating a session to web
server 172.16.0.5 on the DMZ network?
access-list NO_NAT permit ip host 10.0.0.101 172.16.0.32 255.255.255.224
nat-control
nat (inside) 5 access-list NO_NAT
nat (inside) 1 10.0.0.0 255.255.255.0 tcp 0 0 udp 0
nat (inside) 2 0.0.0.0 0.0.0.0 tcp 0 0 udp 0
global (outside) 1 209.165.200.235-209.165.200.254 netmask 255.255.255.224
global (DMZ) 2 172.16.0.101-172.16.0.254 netmask 255.255.255.0
global (DMZ) 5 interface
The answer is that the NAT would fail and I am not 100% sure why. Here is how I understand it
The NO_NAT (NAT_ID 5) is an exemption rule to avoid nattide when going to that address.
The NAT_ID 1 :
is for the outside interface so does not apply in this case.
The NAT_ID 2:
Appears to Natting everything  on the DMZ interface to 172.16.0.101-172.16.0.254 netmask 255.255.255.0; so once it is natted should it be able to communited with server 172.16.0.5 on the DMZ network?
Mohamed Sobair
Level 7
Level 7
Yes, Communication with the current config would fail!
You just need to correct it to the following if you need host 10.0.0.101 NOT to be natted when connecting to Servers in the DMZ Network:
nat (inside) 0 access-list NO_NAT
access-list NO_NAT permit ip host 10.0.0.101 host 172.16.0.5
Mohamed
Here are the list of answers and D is the correct one:
a. 172.16.0.1 (the ASA DMZ interface IP)
b. 172.16.0.101
c. 209.165.200.235
d. None of these answers are correct because the translation attempt will fail.
But as I explained before wouldn't the config below NAT the address?
The NAT_ID 2:
Appears to Natting everything  on the DMZ interface to 172.16.0.101-172.16.0.254 netmask 255.255.255.0; so once it is natted should it be able to communited with server 172.16.0.5 on the DMZ network?  Why would the NAT attempt fail?
The example illustrate of Natting all inside interface subnet when communicating with the DMZ. The Nat in this case wouldnt fail, and if the Inside needs to access the (172.16.0.5), it will be possible.
However, Just make sure there is no Overlaping of addresses from the source to the destination whenever NAT Occurs!
Mohamed
