Help with 1841 & WIC-1SHDSL-V3
rtw00ten1
I'm trying to set up my Cisco 1841 with a with SDSL service.  I have the WIC-1SHDSL-V3 card installed in the router and have followed the configuration example at: http://www.cisco.com/en/US/docs/ios/bbdsl/configuration/guide/bba_atm_shdsl_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1052601
however, no mater what I do, I can't get it to work.  On a "show interface atm0/0/0" the interface is shown as "ATM0/0/0 is initializing, line protocol is down"  It should be noted that I do not need to use NAT as I have some public IP address that we plan to use with the SDSL circuit.  My config is posted below:
version 12.4
hostname CiscoR1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
dot11 syslog
ip source-route
ip cef
ip name-server 199.xxx.xxx.xxx
ip name-server 66.xxx.xxx.xxx
no ipv6 cef
username admin privilege 15 view root secret password
archive
log config
  hidekeys
controller DSL 0/0/0
mode atm
line-mode auto standard
interface FastEthernet0/0
ip address 199.xxx.xxx.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
ip address 66.xxx.xxx.68 255.255.255.0
atm ilmi-keepalive
pvc 0/38
  encapsulation aal5snap
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 ATM0/0/0
ip http server
ip http authentication local
no ip http secure-server
control-plane
line con 0
logging synchronous
login local
line aux 0
line vty 0 4
login local
scheduler allocate 20000 1000
ntp server 192.43.244.18
ntp server 129.6.15.28
ntp server 192.5.41.40
ntp server 128.138.140.44
ntp server 132.163.4.101
end
Juan Perez
What is the status of the controller DSL "show controller dsl x/y/z". Please also set termination mode and standard "line-term cpe" "dsl-mode shdsl symmetric annex a-b", moreover is this a 2-wire or 4-wire connection? TRy hardcoding mode as well.
Regards.
I have set the "line-term cpe" and "dsl-mode shdsl symmetric annex a" but they don't show in the config because those are the system defaults.  When I do a "show controller dsl 0/0/0" I get the following:
CiscoR2#show controller dsl 0/0/0
DSL 0/0/0 controller DOWN
Globespan xDSL controller chipset
DSL mode: Not Trained
Frame mode: Utopia
Configured Line rate: 4608Kbps
Line Re-activated 0 times after system bootup
LOSW Defect alarm: ACTIVE
CRC per second alarm: ACTIVE
Line termination: CPE
FPGA Revision: 0xB3
Line 0 statistics
        Current 15 min counters
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 247
        Previous 15 min counters
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 900
        Current 24 hr counters
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 2947
        Previous 24 hr counters
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 0
Line 1 statistics
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 255
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 2879
Line-0 status
Chipset Version:  0
Firmware Version:  R4.3.1
Modem Status:  Handshake, Status 10
Last Fail Mode:  No Failure status:0x0
DSL firmware download in progress, please wait
Line-1 status
Chipset Version:  0
Dying Gasp: Present
That is correct, those values are set by default but what I tried to recommend was to apply annex a-b, have you confirmed with your ISP the values you should use, is this 2-wire or 4-wire? Line is not coming up because of a layer 1 problem (negotiation not established).
Regards.
