Help with a simple config on 871
I'm a really basic Cisco user and I'm having issue with a simple config I'm trying to do.
Basically, I'd like to use a 871 as a bandwidth limiter.
I use a ISP modem-router with a 192.168.2.0/24 network and I'd like enter 50Mbps Internet bandwidth in one port of the 871 and give one of the Fe port with speed 10 and a 192.168.0.0/24 network.  Furthermore, I'd install an access point in that port and I don't want those users to have access to the 192.168.2.0 network.  I use this config right now:
version 12.4
no service pad
hostname MyRouter
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1
ip dhcp pool MyDhcp
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 192.168.2.1
interface FastEthernet0
switchport access vlan 10
ip dhcp client hostname MyDhcp
speed 10
no cdp enable
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.0.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.2.1
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Here's the sh ip route:
Gateway of last resort is 192.168.2.1 to network 0.0.0.0
C    192.168.0.0/24 is directly connected, Vlan10
C    192.168.2.0/24 is directly connected, FastEthernet4
S*   0.0.0.0/0 [1/0] via 192.168.2.1
I'm able to ping both google.ca and the pc (192.168.0.2) from the router, but from the PC I can ping 192.168.0.1 but not 192.168.2.1.
I'm also sure it's a quite simple thing for most of you guys to figure out.  But again, I'm a quite basic Cisco user.
Thank you very much in advance.
Yannick.
xlhardwarestore
Have you tried it with NAT?
access-list 1 permit 192.168.0.0 0.0.0.255
ip nat inside source list 1 interface FastEthernet4 overload
interface vlan10
ip nat inside
ip nat outside
no switchport
xlhardwarestore
interface vlan10
ip nat inside
ip nat outside
no switchport
Yes it works!! Thanks hundred times.  I don't really understand what those functions are for but it does work!  I assume that Ip nat outside means the network address translation for WAN and inside for LAN.
Do the access list above means that in slot number 1, what comes from 192.168.0.0 network is permit, and source list 1 is calling that function back and assign it to fa4?  Meaning that what comes from 192.168.0.0 going to fa4 is allowed?
I'm really thankful to you Umit Sencan!
Yes, basically that's correct, since you have 2 different subnet and a router, LAN side needs to be translated into WAN side. You can make the network very secure by changing access list to extented list. 1-99 is for standard, 100 and over for extended access list. Below is an example, you can control which ports to open or closed
ip access-list extended INTERNET
deny tcp any any eq 5060 log
deny udp any any eq 5060 log
deny udp any any eq 2427 log
deny tcp any any eq 2428 log
deny tcp any any range 1718 1720 log
deny tcp any any eq 1731 log
deny tcp any any eq 2000 log
deny tcp any any eq 3389
deny tcp any any eq 23
deny tcp any any eq ftp
deny tcp any any eq ftp-data
deny tcp any any eq 22
permit tcp any any eq www
ip inspect name FIREWALL tcp
ip inspect name FIREWALL udp
ip inspect name FIREWALL cuseeme
ip inspect name FIREWALL ftp
ip inspect name FIREWALL h323
ip inspect name FIREWALL realaudio
ip inspect name FIREWALL rtsp
ip inspect name FIREWALL pptp
ip inspect name FIREWALL sip
ip inspect name FIREWALL vdolive
ip inspect name FIREWALL streamworks
ip inspect name FIREWALL netshow
ip inspect name FIREWALL sqlnet
ip inspect name FIREWALL tftp
ip inspect name FIREWALL skinny
ip inspect name FIREWALL ntp
ip inspect name FIREWALL dns
ip nat outside
no switchport
ip access-group INTERNET in
ip inspect FIREWALL out
