Help with configuring an Access server (2511)
newnetman
Hello All,
May i ask someone to please take the pain of taking me through configuring an access server (2511)?.
I have number of routers and switches, i would like to be reserve telneting to and from the access server but my ideas as formally requested doesn't seem to work.
Will be most grateful if any one can please take me through the steps of getting it done.
Thanking you all in advance.
Here is my 2511 config. Adapt as needed..
Telnet onto the 2511 Ethernet interface followed by the port.
Telnet 192.168.1.253 2001 for the router on Async 1.
Current configuration : 1314 bytes
version 12.3
hostname cisco2511
boot-start-marker
boot-end-marker
enable secret xxx
enable password password
no aaa new-model
ip subnet-zero
no ip routing
ip host R1 2001 192.168.1.253
ip host R2 2002 192.168.1.253
ip host R3 2003 192.168.1.253
ip host R4 2004 192.168.1.253
ip host R5 2005 192.168.1.253
ip host R6 2006 192.168.1.253
ip host R7 2007 192.168.1.253
ip host R8 2008 192.168.1.253
ip host R9 2009 192.168.1.253
ip host R10 2010 192.168.1.253
ip host R11 2011 192.168.1.253
ip host R12 2012 192.168.1.253
ip host R13 2013 192.168.1.253
ip host R14 2014 192.168.1.253
ip host R15 2015 192.168.1.253
ip host R16 2016 192.168.1.253
interface Ethernet0
ip address 192.168.1.253 255.255.255.0
no ip route-cache
no keepalive
interface Serial0
no ip address
no ip route-cache
shutdown
interface Serial1
no ip address
no ip route-cache
shutdown
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.254
line con 0
line 1 16
session-timeout 30
exec-timeout 0 0
no exec
transport input telnet
line aux 0
line vty 0 4
password password
login
end
I don't see a problem based on your config.
I also noticed you are working with Rick in another thread.
In order to avoid any confusion, please continue on the other thread with Rick and follow his guidance.
__
Edison.
