Help with GRE tunnel, P2P with loopbacks
codystaf1
I am new to networking, any help would be greatly appreciated!! I have been searching for hours and can't fix this for the life of me. Thanks for reading/helping. It is point-to-point routers that must have GRE tunneling between them. This is a similar version of the issue at my work that I am trying to fix/learn on GNS3 to replicate in the production environment. It must use loopback for the source and static route (outside of my control).
R3
interface Loopback0
ip address 10.0.0.1 255.255.255.255
interface Tunnel1
ip address 172.16.1.1 255.255.255.0
tunnel source Loopback0
tunnel destination 1.1.1.2
interface Ethernet0/0
description Trunk to R4
ip address 1.1.1.1 255.255.255.252
interface Ethernet0/1
description Fake network to fake computer
ip route 10.0.0.2 255.255.255.255 172.16.1.2
ip route 192.168.2.0 255.255.255.0 172.16.1.2
R4
interface Loopback0
ip address 10.0.0.2 255.255.255.255
interface Tunnel1
ip address 172.16.1.2 255.255.255.0
tunnel destination 1.1.1.1
description Trunk to R3
ip address 1.1.1.2 255.255.255.252
ip address 192.168.2.2 255.255.255.0
ip route 10.0.0.1 255.255.255.255 172.16.1.1
ip route 192.168.1.0 255.255.255.0 172.16.1.1
-In this configuration, I can ping the physical interfaces of 1.1.1.1 and 1.1.1.2 but that is it.
R3
1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 1.1.1.0/30 is directly connected, Ethernet0/0
L 1.1.1.1/32 is directly connected, Ethernet0/0
10.0.0.0/32 is subnetted, 2 subnets
C 10.0.0.1 is directly connected, Loopback0
S 10.0.0.2 [1/0] via 172.16.1.2
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.1.0/24 is directly connected, Tunnel1
L 172.16.1.1/32 is directly connected, Tunnel1
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Ethernet0/1
L 192.168.1.1/32 is directly connected, Ethernet0/1
S 192.168.2.0/24 [1/0] via 172.16.1.2
R4
L 1.1.1.2/32 is directly connected, Ethernet0/0
S 10.0.0.1 [1/0] via 172.16.1.1
C 10.0.0.2 is directly connected, Loopback0
L 172.16.1.2/32 is directly connected, Tunnel1
S 192.168.1.0/24 [1/0] via 172.16.1.1
192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.2.0/24 is directly connected, Ethernet0/1
L 192.168.2.2/32 is directly connected, Ethernet0/1
R3
IOU3(config-if)#do sh int tu1
Tunnel1 is up, line protocol is up
Hardware is Tunnel
Internet address is 172.16.1.1/24
MTU 17916 bytes, BW 100 Kbit/sec, DLY 50000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel linestate evaluation up
Tunnel source 10.0.0.1 (Loopback0), destination 1.1.1.2
Tunnel Subblocks:
src-track:
Tunnel1 source tracking subblock associated with Loopback0
Set of tunnels with source Loopback0, 1 member (includes iterators), on interface <OK>
Tunnel protocol/transport GRE/IP
Key disabled, sequencing disabled
Checksumming of packets disabled
R4
IOU4(config-if)#do sh int tu1
Hardware is Tunnel
Internet address is 172.16.1.2/24
Keepalive not set
Tunnel source 10.0.0.2 (Loopback0), destination 1.1.1.1
Tunnel Subblocks:
src-track:
-In the below configuration it works but I still need to use the loopback like above. Can ping both sides of tunnel and the 192 network
(Same as above setup P2P with only one link to each other, except no loopback used and only one ip route)
R1
interface Tunnel1
tunnel source 1.1.1.1
end
IOU1(config-if)#do sh run | i ip route
R2
interface Tunnel1
tunnel source 1.1.1.2
IOU2(config-if)#do sh run | i ip route
Harold Ritter
Hi @codystaf1 .
The tunnel source should match the tunnel destination on the other router and vice versa.
And if you are going to use the loopback interface as the destination address for the tunnel, you should also make sure the peer router loopback interface is reachable via the physical interface between the two routers, rather than the tunnel interface.
R3:
int tu1
tunnel destination 10.0.0.2
no ip route 10.0.0.2 255.255.255.255 172.16.1.2
ip route 10.0.0.2 255.255.255.255 1.1.1.2
R4:
int tu1
tunnel destination 10.0.0.1
no ip route 10.0.0.1 255.255.255.255 172.16.1.1
ip route 10.0.0.1 255.255.255.255 1.1.1.1
That should fix it.
In you configuration change the static routes to reflect a next hop of the physical interface of the connecting router,
Example:
R3
interface Loopback0
interface Tunnel1
R4
interface Loopback0
interface Tunnel1
-David
Harold Ritter
Hi @codystaf1 .
R3:
int tu1
R4:
int tu1
That should fix it.
