Help with inter-vlan routing
E419
Curious if anyone can help me. I'm working on CCNA and have been playing around in packet tracer. below is a Lab that I made for myself. My issue is that I can ping between each switch to the router on the connected sub interfaces. However I cannot ping from the switches on one side to the other or the opposite sub interfaces (192.168.1.X cannot ping 192.168.2.X & vice versa)
I have verified both switches on either end of the router has correct IPs for each VLAN, and are trunked to the router. The router sub interfaces have correct IPs and encapsulation  dot1Q [vlan #]. I have also tried configuring routes with OSPF and static separately.
I am still a little new to networking so I apologize if I just don't understand something. If anyone can help understand and fix the issue I would appreciate it. P.S. sorry for the bit of a un-organized IP scheme.
Hello
Your interface addressing and tagging on the rtrs subinterfaces conflict
example:
interface GigabitEthernet0/1.2
encapsulation dot1Q 20
ip address 192.168.1.72 255.255.255.192
interface GigabitEthernet0/2.2
ip address 192.168.2.71 255.255.255.192
Based on your OP it suggests you are using the rtr as a Router On A Stick (ROAS) meaning using the router to perform the intervlan routing for the LAN, however as you have a L2 switch attached to both physical interfaces on the router, So it would be applicable to use IRB ( Intergrated Route Bridging)
Review attached file:
Kind Regards
Paul
balaji.bandi
The images does not show us what interface connected to Router on each side switch.
can you post below information from all devices ;
show run
show IP interface brief
show IP arp
show cdp neigh
show vlan
BB
Can do, also included
show int trunk
for the switches. please see attachments.
Hello
example:
Kind Regards
Paul
I did not know about IBR and I was obviously confused a little on how vlans and Subnets work on routers. Thanks for the help and teaching me something new.
