Help with Interfaces Errors on Satellite WAN Circuit
wedwardsvt
Hello all,
I have recently connected my site to a remote office using a 9.744 Mbps point-to-point serial circuit over Satellite. I am seeing very strange errors on the interfaces and would appreciate assistance. Please reference the attached network diagram with the follow-up post containing the "show interfaces" below. The connection from my building to the satellite teleport is over ATM. I am seeing "output drops" on both sides of ATM circuit. The ATM circuit is one 9.744 Mbps PVC. I am also seeing errors on both HSSI interfaces. The HSSI circuit is timed off the satellite modem that is connected to the HSSI interface of Router B. I noticed by doing a show controllers that the receicved timing on the HSSI interface moves from 9743538 to 9745120 approximtely once every 30 seconds. However, I can not directly correlate the timing drift to the interface errors.
Thank you for your help.
5 Replies 5
wedwardsvt
Router A ATM Interface (ATM 2/0):
RouterA#sh int atm 2/0
ATM2/0 is up, line protocol is up
Hardware is RS8234 ATM DS3
Description: ATM Trunk
MTU 4470 bytes, sub MTU 4470, BW 45000 Kbit, DLY 190 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5
1023 maximum active VCs, 2 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 5w0d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 8901043
Queueing strategy: Per VC Queueing
30 second input rate 131000 bits/sec, 14 packets/sec
30 second output rate 47000 bits/sec, 14 packets/sec
121292189 packets input, 741762298 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 5 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
112122802 packets output, 3956918578 bytes, 0 underruns
Router B ATM Interface (atm 4/0):
RouterB#sh int atm 4/0
ATM4/0 is up, line protocol is up
Description: ATM
MTU 4470 bytes, sub MTU 4470, BW 9744 Kbit, DLY 190 usec,
1023 maximum active VCs, 1 current VCCs
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d22h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 194973
30 second input rate 43000 bits/sec, 8 packets/sec
30 second output rate 8000 bits/sec, 7 packets/sec
13834546 packets input, 3469090240 bytes, 0 no buffer
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
15460961 packets output, 123454412 bytes, 0 underruns
Router B HSSI interface (hssi 3/0):
RouterB#sh int hssi 3/0
Hssi3/0 is up, line protocol is up
Hardware is M1T-HSSI-B
Description: SATCOM LINK
Internet address is 10.1.2.5/30
MTU 4470 bytes, BW 9744 Kbit, DLY 200 usec,
Encapsulation PPP, LCP Open
Open: IPCP, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:03, output 00:00:00, output hang never
Last clearing of "show interface" counters 02:52:13
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 6000 bits/sec, 6 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
128737 packets input, 17418447 bytes, 0 no buffer
0 parity
584 input errors, 574 CRC, 0 frame, 5 overrun, 0 ignored, 5 abort
138174 packets output, 87933979 bytes, 0 underruns
0 output errors, 0 applique, 0 interface resets
0 carrier transitions LC=down CA=up TM=down LB=down TA=up LA=down
HSSI DTE, received clockrate 9745120
HSSI DTE, received clockrate 9743538
Router C HSSI Interface (hssi 1/0):
RouterC#sh int hssi 1/0
Hssi1/0 is up, line protocol is up
Internet address is 10.1.2.6/30
Last clearing of "show interface" counters 2d02h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 9917
30 second input rate 24000 bits/sec, 8 packets/sec
30 second output rate 7000 bits/sec, 8 packets/sec
15556907 packets input, 1154275136 bytes, 0 no buffer
Received 0 broadcasts, 202 runts, 0 giants, 0 throttles
0 parity
4858695 input errors, 2514675 CRC, 0 frame, 1380169 overrun, 0 ignored, 963851 abort
18890347 packets output, 1964671150 bytes, 2316 underruns
only router C has a severely errored interface, can you have the satellite modem checked for correct SNR as likely the problem lies in there.
As you see on router B the HSSI clock can fluctuate a little without causing any problem.
Thank you very much for the reply. We're currently looking into replacing the SAT modem connected to router C. The circuit had been running pretty well for about 4 weeks until we begun seeing errors this past week. What concerns me are the output packet drops on the ATM interface. I have noticed the clock fluctuating on the HSSI interface from 9743538 to 9745528, while the ATM is a constant 9744000. Do you think that the mismatch of speeds could be causing this? If not, do you have any ideas on how I could troubleshoot?
Hi, if had worked 4 fine weeks it's just a matter of checking something on the dish and related equipment and fix it. For example a faulty lnb can bring SNR low enough for the error correction on the sat link not suffice anymore.
