05-27-2011 07:26 AM - edited 03-04-2019 12:32 PM
Ok here is what I did; but doesnt seem to function.
switch 1
config t
int range g3/9 -13, g3/19
channel-group 2 mode on
int po2
switchport
switchport mode trunk
description Trunk connection for L2 Vlans to r2-Router
switchport trunk allowed vlan x,x,x,x,x,x,x,x,x,x,
switchport trunk allowed vlan add x,x,x,x,x,x,x,x,
switchport trunk allowed vlan add x.x.x.x.x.x.x.x.
no snmp trap link-status
mls qos trust dscp
Switch 2
config t
int po2
switchport
description Trunk connection for L2 Vlans to r1-Router
mls qos trust dscp
then went to both switches and did a no shut on all interfaces that are included in this config...
sorry this is between 2 6509 devices.
05-27-2011 08:25 AM
show int status and sh int trunk on both switches as well as sh ether summary then post here.
Regards.
Alain
05-27-2011 08:45 AM
I cant currently because this was a change i implemnted last night and it failed so I had to remove configs.
When I looked at switch 1 everything was up and fine..
when I looked at switch 2 nothing was up ..no po2 interface nor the physical interfaces.
Im guessing maybe syntax error cause I know if they dont match exactly it wont come up on the far side...
05-29-2011 07:34 AM
switch 1
config t
u have to add trunk at int level as well
secondly always save sh ether-channel summary etc
