Help with multicast setup
perpaal
Hi, I`m attempting to set up a multicast in ouer network.
The multicast is provided by a IPTV provider.
Uplink from service provider is located at site A.
My RP is set up at site B.
From site A to B I have set up a VLAN (VLAN 400) to link the IPTV provider uplink to my RP.
The IPTV providers uplink is located at port 3 on site A.
On site B I have defined a VLAN (800) where I want to connect the multicast clients.
In VLAN 800 I connect a PC trying to connect to one of the multicast services with VLC (from instructions from IPTV provider), but it does not work.
This is my first multicast setup, so I probably have some mistakes in my config.
Need some good tips fast here
This is my current config:
Site A: Cisco 3750
ip vrf multicast
rd 1:2
ip vrf Management
rd 1:1
ip multicast-routing vrf multicast distributed
vlan 500
name Management
vlan 400
name Linknet_IPTV
interface GigabitEthernet1/0/1
description Link_site_B
switchport mode trunk
interface GigabitEthernet1/0/3
description Link_to IPTV_provider
switchport access vlan 400
switchport mode access
interface Vlan500
ip vrf forwarding Management
ip address 10.1.0.2 255.255.255.0
interface Vlan400
ip vrf forwarding multicast
no ip address
ip pim sparse-mode
Site B: Cisco 3750
system mtu routing 1500
vtp mode transparent
ip routing
ip vrf multicast
rd 1:2
ip vrf Management
rd 1:1
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 500
name Management
vlan 400
name Linknet_IPTV
vlan 800
name Multicast
interface Loopback1
description RP-Local
ip address 10.150.0.134 255.255.255.255
ip pim sparse-mode
interface GigabitEthernet2/0/1
description Link_site_A
interface Vlan500
ip address 10.1.0.1 255.255.255.0
interface Vlan400
ip address 10.250.250.2 255.255.255.252
ip pim sparse-mode
interface Vlan800
ip address 10.160.0.1 255.255.255.0
ip pim sparse-mode
ip route vrf multicast 0.0.0.0 10.250.250.1
ip pim vrf multicast rp-address 10.150.0.134
ip msdp vrf multicast peer 10.10.0.15 connect-source Loopback1
ip msdp vrf multicast description 10.10.0.15 ##Multicast##
ip msdp vrf multicast cache-sa-state
ip msdp vrf multicast rpf rfc3618
Your neighbor information will be under vrf multicast, thus the command is show ip pim vrf multicast neighbor
Do you see it now?
If not, then the provider does not have PIM enabled on their L3 interface that is connected to your L2 switch (interface
10.250.250.1/30)
8 Replies 8
Vaibhava Varma
Level 4
Level 4
Hi perpaal
Can you confirm your current deployment setup..will be good if you can share a network topology diagram..From reading above I understand this
Users------Vlan800--SiteB-----Vlan400(PIM)----SiteA (L2)---Vlan400(PIM)---ISP (IPTV Provider)
SiteA is just L2 for your setup.So the issue lies at SiteB. Has the ISP agreed to do MSDP peering with you. Does the ISP has reverse route for VLAN800 and Lo1.
Can you share below outputs
sh ip pim neighbour
sh ip pim rp mapping
sh ip mroute
sh ip msdp peer
sh ip msdp sa
Varma
Thank you for quick reply.
Site A is just L2 that is correct.
IPTV service provider har agreed to MSDP peering.
The ISP has reverse routes to my network.
sh ip pim vrf multicast neighbour = Empty table
sh ip pim vrf multicast rp = Empty table
sh ip mroute vrf multicast=
(*, 224.0.1.40), 01:34:39/00:02:55, RP 0.0.0.0, flags: DCL
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Loopback0, Forward/Sparse, 01:34:38/00:02:55
sh ip msdp vrf multicast peer=
MSDP Peer 10.10.0.15 (?), AS ?
Description: #Provider RP#
Connection status:
State: Up, Resets: 0, Connection source: Loopback0 (141.0.224.134)
Uptime(Downtime): 01:19:31, Messages sent/received: 79/859
Output messages discarded: 0
Connection and counters cleared 01:34:21 ago
SA Filtering:
Input (S,G) filter: none, route-map: none
Input RP filter: none, route-map: none
Output (S,G) filter: none, route-map: none
Output RP filter: none, route-map: none
SA-Requests:
Input filter: none
Peer ttl threshold: 0
SAs learned from this peer: 392
Number of connection transitions to Established state: 1
Input queue size: 0, Output queue size: 0
sh ip msdp vrf multicast sa=
MSDP Source-Active Cache - 393 entries
And a list of these entries ....
Before we start troubleshooting multicast, let's examine your unicast routing.
Does the IPTV provider knows about subnet 10.160.0.0/24?
I see the switch has a default route towards 10.250.250.1 but they need to have a subnet route back to 10.160.0.0/24.
Can you ping the IPTV source from your PC running VLC?
Also, if you are running VLC - I believe you have to modify the TTL which defaults to 1. I personally have never used VLC for multicast testing because it tends to be buggy.
If you were using a multicast client, we should be able to see a *,G for the intended group in your local RP. Your mroute table is empty.
Edison
Yes the provider has the 10.160.0.0 net in its routes.
I can ping the providers RP (MSDP peer) from the PC.
But I do not get any PIM  neighbour, should there be anything here?
What might be the reason that I do not get this, is there somethins missing in my config, or is it at the providers side?
Do you see it now?
10.250.250.1/30)
Hi perpaal
PIM neighbourship would be required between the Site B and ISP for completing the mutlicast traffic path in Inter-AS Multicast Scenario when using MSDP. ( Though I have seen the first mcast flow to work in Inter-AS even wothout PIM but later traffic drops) so we wll need PIM to be enabled by the ISP on their downlink interface to SiteA as one important condition for multicast traffic to flow is that uRPF neighbour should be same as PIM neighbour for multicast traffic to flow which is not happening here.
Also very important point is to disable the flow of multicast packets between Site B and ISP in this scenario so that no unwanted updates cross between SiteB and ISP. We would need to block 224.0.1.39 and 224.0.1.40 between the Site B and ISP using ACL and permit rest.
A sample config would be:
int vlan400
ip pim sparse-mode
ip multicast boundary 1
access-list 1 deny 224.0.1.39
access-list 1 deny 224.0.1.40
access-list 1 permit any
Please have the ISP enable PIM on their downlink interface and configure the multicast boundary as above ( also remind ISP for multicast boundary or bsr-border if using BSR) and we should be good to go as the MSDP is up and its caching the multicast states fine. Also the uRPF should be fine now since we have only single routing path between SiteB and ISP and we have all the required routing in place.
Hope this helps to resolve your issue. Do let know for any clarifications and how we move ahead on this issue,
Varma
Thank you for great help.
The problem was at the service providers side, even though they assured me that they had all set up
They had not set pim sparse-mode at the interface.
Now it works like a charm.
Hiperpaal
Glad to hear its working now.
Varma
