Unable To Ping across subinterface on 1941w
pugs17211721
I am currently working on a 1941w router. The problem that I am having is that I am unable to ping the switch that is directly connected to it and I am unable to ping from the switch to the router. If I take the address off of vlan 1 and move it to gi0/0.1 the pings work, but then client traffic on the wireless ap inside the 1941w fails. Can someone please help ? Thanks
Here is the releveant config off of the 1941w
version 15.0
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname SATX-1941W-001
boot-start-marker
boot-end-marker
logging buffered 16384 notifications
enable secret 5 $1$kGmQ$r2bXwOVZ8ffF0A0i.T8j6.
no aaa new-model
memory-size iomem 10
clock timezone EST -5
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip source-route
ip cef
ip dhcp database CLIENT write-delay 120 timeout 60
ip dhcp excluded-address 10.11.12.1
ip dhcp excluded-address 172.21.18.1 172.21.18.99
ip dhcp excluded-address 172.21.18.200 172.21.18.254
ip dhcp pool VLAN2
   import all
   network 10.11.12.0 255.255.255.0
   dns-server 192.69.21.200 206.51.156.28
   default-router 10.11.12.1
ip dhcp pool CLIENT
   import all
   network 172.21.18.0 255.255.255.0
   default-router 172.21.18.1
   domain-name us.crownlift.net
   dns-server 172.20.62.208 192.69.21.200
   lease 365
no ip domain lookup
ip domain name dicke.com
ip name-server 192.69.21.200
license udi pid CISCO1941W-A/K9 sn FTX152884V7
hw-module ism 0
archive
log config
  hidekeys
username (removed) privilege 15 secret 5 (removed)
redundancy
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key (FLOH-IPSEC-KEY) address (FLOH-VPN-TARGET)
crypto isakmp key (NBOH-IPSEC-KEY) address (NBOH-VPN-TARGET)
crypto ipsec transform-set DES-3SHA esp-3des esp-sha-hmac
crypto map 108T-FA000 local-address FastEthernet0/0/0
crypto map 108T-FA000 30 ipsec-isakmp
set peer (NBOH-VPN-TARGET)
set transform-set DES-3SHA
match address NBOH
crypto map 108T-GI01 local-address GigabitEthernet0/1
crypto map 108T-GI01 31 ipsec-isakmp
set peer (FLOH-VPN-TARGET)
match address FLOH
bridge irb
interface Loopback0
ip address 172.21.100.18 255.255.255.255
interface Tunnel30
description T-NBOH
ip address 172.20.255.102 255.255.255.252
ip mtu 1500
ip flow ingress
keepalive 10 3
tunnel source 172.21.100.18
tunnel destination 172.20.240.2
interface Tunnel31
description T-FtLoramie-Family
ip address 172.20.255.98 255.255.255.252
ip mtu 1500
ip flow ingress
keepalive 10 3
tunnel destination 172.20.240.31
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
interface GigabitEthernet0/0
no ip address
ip flow ingress
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0.1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
encapsulation dot1Q 1 native
ip flow ingress
ip virtual-reassembly
bridge-group 1
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip flow ingress
ip nat inside
bridge-group 2
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
description $ES_WAN$$FW_OUTSIDE$
ip address (CABLE-MODEM-IP) 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
no cdp enable
interface FastEthernet0/0/0
ip address (DSL-MODEM-IP) 255.255.255.248
ip access-group LetIn in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
no cdp enable
interface Vlan1
ip address 172.21.18.1 255.255.255.0
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
no autostate
interface Vlan2
ip address 10.11.12.1 255.255.255.0
ip flow ingress
no autostate
bridge-group 2
ip default-gateway (DSL-MODEM-GW)
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export source Tunnel31
ip flow-export version 5
ip flow-export destination 172.20.62.245 6343
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 2 interface FastEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 (DSL-MODEM-GW)
ip route 0.0.0.0 0.0.0.0 (CABLE-MODEM-GW) 20
ip route 172.20.0.0 255.255.0.0 Tunnel31
ip route 172.20.0.0 255.255.0.0 172.20.255.97
ip route 172.20.0.0 255.255.0.0 172.20.255.101 20
ip route 172.20.0.0 255.255.0.0 Tunnel30 20
ip route 172.20.240.2 255.255.255.255 (DSL-MODEM-GW)
ip route 172.20.240.31 255.255.255.255 (CABLE-MODEM-GW)
ip route (NBOH-VPN-TARGET) 255.255.255.255 (DSL-MODEM-GW)
ip route (FLOH-VPN-TARGET) 255.255.255.255 (CABLE-MODEM-GW)
paolo bevilacqua
You should have that address on BVI1 interface. Put vlan1 and g0/0.1 in bridge-group 1.
Also need bridge-group 1 route ip.
pugs17211721
Also here is the embedded ap config as well.
version 12.4
no service pad
hostname SATX-1941WAP-001
enable secret 5 $1$VTeU$/NaH66RuXZYkJBnwgce4f1
aaa new-model
aaa session-id common
clock summer-time EDT date Mar 11 2007 2:00 Nov 4 2007 2:00
ip name-server 172.20.62.208
ip name-server 172.20.108.123
dot11 syslog
dot11 ssid Gadget2
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 08025E411E1726181C1F1E0B263875716760
dot11 ssid Gizmo
   vlan 2
   authentication open
   mbssid guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 2 key 1 size 40bit 7 80E035FA9F96 transmit-key
encryption vlan 2 mode ciphers tkip wep40
ssid Gadget2
ssid Gizmo
antenna gain 0
mbssid
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
no cdp enable
interface Dot11Radio0.1
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
ip helper-address 10.11.12.1
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Gadget2
ssid Gizmo
antenna gain 0
dfs band 3 block
mbssid
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
no cdp enable
bridge-group 1
interface Dot11Radio1.2
no ip route-cache
no cdp enable
bridge-group 2
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 172.21.18.10 255.255.255.0
no ip route-cache
ip default-gateway 172.21.18.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging 172.20.62.158
logging 172.20.62.110
access-list 61 permit 172.20.62.100
access-list 61 deny   any
snmp-server community crownsee RO
snmp-server community C$0w^W$1T# RW 61
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps entity
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps config
snmp-server enable traps aaa_server
snmp-server host 172.20.61.7 SNMPv2
snmp-server host 172.20.62.100 SNMPv2
snmp-server host 172.20.1.164 s8n1mp
bridge 1 route ip
line con 0
privilege level 15
no activation-character
line vty 5 15
sntp server 172.20.100.1
sntp server 172.20.100.2
cns dhcp
end
paolo bevilacqua
That worked, thanks for your help
