Help with Netflow analyzer settings on router
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-08-2007 12:34 PM - edited 03-03-2019 07:04 PM
I have a Cisco 877 and 837 in VPN modes and I am trying to them to forward traffic info to a Netflow server, but nothing shows on the Netflow Analyzer website. I have added the follow;
router#configure terminal
router(config)#interface Ethernet 0
router(config-if)#ip route-cache flow
router(config-if)#exit
router(config)#ip flow-export destination 192.168.9.101 9996
router(config)#ip flow-export source Ethernet 0
router(config)#ip flow-export version 5
router(config)#ip flow-cache timeout active 1
router(config)#ip flow-cache timeout inactive 15
Router#sh ip flow export
Flow export v5 is enabled for main cache
Exporting flows to 192.168.9.101 (9996)
Exporting using source interface Ethernet0
Version 5 flow records
2004 flows exported in 677 udp datagrams
0 flows failed due to lack of export packet
0 export packets were sent up to process level
0 export packets were dropped due to no fib
0 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
Router#
and
Router#sh ip cache flow
IP packet size distribution (132290 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .704 .025 .100 .028 .054 .021 .011 .007 .001 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.000 .000 .000 .002 .037 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
1 active, 4095 inactive, 2014 added
69717 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 21640 bytes
1 active, 1023 inactive, 2004 added, 2004 added to flow
0 alloc failures, 0 force free
1 chunk, 1 chunk added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-WWW 182 0.0 8 202 0.0 2.6 4.9
TCP-SMTP 377 0.0 1 60 0.0 0.9 15.5
TCP-other 1041 0.0 124 126 3.9 44.5 7.4
UDP-DNS 115 0.0 1 71 0.0 1.4 15.4
UDP-NTP 35 0.0 1 96 0.0 0.0 15.5
UDP-other 108 0.0 1 333 0.0 0.2 15.4
ICMP 155 0.0 2 281 0.0 1.1 15.5
Total: 2013 0.0 65 127 4.0 23.6 10.3
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Et0 172.39.10.20 Di1 192.168.211.8 06 0695 0A26 382
router#
- Labels:
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-08-2007 12:54 PM
Andy
the show ip cache flow clearly shows that the router is generating netflow data. If it is not getting to the analyzer there are a couple of things that I would suggest that you check:
- is there IP connectivity from the router to the address of the analyzer (192.168.9.101)?
- is the analyzer listening on port 9996?
- is the analyzer processing format version 5 packets?
- is there possibly any access list between the router and the analyzer which is not permitting UDP port 9996 to pass?
I would suggest that you do an extended ping from the router and in the extended ping specify 192.168.9.101 as the destination and specify ethernet 0 as the source. And if the extended ping does work then I would suggest an extended trace with destination 192.168.9.101 and source as ethernet 0 (to check on UDP packets instead of ICMP packets).
Rick
Rick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-08-2007 02:24 PM
Hi Rick, how do I do an extended ping? Plus I don't think from memory I have a permit rule for this, what should the permit rule look like?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-08-2007 02:43 PM
Andy
For extended ping you must be in privilege mode and you enter the command ping and press enter. The IOS then knows that you want extended ping and it asks a series of questions to get the information it needs to do the extended ping. For this issue the important questions are destination address (192.168.9.101) and when it asks if you want extended commands, you respond yes, and then specify the source address (address of the ethernet interface). Just take the defaults on the other questions by pressing enter.
The format of the permit rule will depend on what platform and on what direction it is being applied.
Rick
Rick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-09-2007 02:17 AM
It seems the extended ping and trace on port 9996 worked.
From the beginning on the Cisco 837 I have added:
configure terminal
routerconfig)#snmp-server ifindex persist
Still no data on the Netflow site. Says flow's received 5 though.
sh ip flow export:
9839 flows exported in 1883 udp datagrams
1 export packets were sent up to process level
