Help with removing command.
V3teran75
Hi i need help in removing a point-to-point configuration.
How do i remove this command
interface Serial0/0/0.201 point-to-point
How do i remove point to point from this serial?
What command do i need to put into packet tracer or cisco router?
John Blakley
no int s0/0/0.201
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
no int s0/0/0.201
HTH,
John
Ok thanks that worked.
Im getting another problem, while trying to configure EIGRP im getting this error
%DUAL-5-NBRCHANGE: IP-EIGRP 100: Neighbor 205.100.80.2 (Serial0/2/0) is down: retry limit exceeded
%DUAL-5-NBRCHANGE: IP-EIGRP 100: Neighbor 205.100.80.2 (Serial0/2/0) is up: new adjacency
Ping connection has failed
Ive been on this today since 12:30 pm over 6 hours and i cant get anywere with it. Not only that but the teacher that i have is useless and dont know how to do it himself. I think i may have just wasted over £1000 in fees. Im really disappointed...
Hi Paul,
Can you post the Eigrp config of routers at both end please along with the interface configs. In your previous post you just disabled the s0/0/0.201 multipoint interface and changed it to a plain simple serial interface, this makes me believe that you were practicing EIGRP in a frame relay environment.  Do you have the other end also as a plain serial interface? and have you connected the two router connected back to back via serial links and not a frame relay switch in between ? A picture of your topology will also help.
Umesh
