08-30-2011 04:09 AM - edited 03-04-2019 01:27 PM
I`m trying to get a simple VRF and routing setup going.
The "routers" are Cisco C3750G-12S-E
What I want to do is separate the management network form all else.
The public network is illustrated with private IP ranges, these are really public ranges.
I think the best way to solve this will be using VRF for management, and regular routing for public network, right?
Putting the management network in it`s own VRF.
But witch routing protocol should I use here...
Very very happy if someone can make me a configuration example
08-30-2011 04:19 AM
quick question are you going to use out of band management ?
what i mean separate interface connected to switch for example just for managment access
08-30-2011 04:31 AM
Management will be inband I guess.
As the link between the routers/switches is leased lines...
08-30-2011 06:44 AM
This is a basic VRF lite configs and should get you up and running. Make sure your IOS version supports VRF. Unless you have non-Cisco devices, i would just stick with EIGRP as the routing protocol.
ROUTER A
ip vrf manage
rd 10:1
interface GigabitEthernet0/0
description Management VRF
ip vrf forwarding manage
ip address 10.10.2.1 255.255.255.0
router eigrp 10 vrf manage
network 10.10.2.0
ROUTER B
ip vrf manage
rd 10:1
ip address 10.10.3.1 255.255.255.0
network 10.10.3.0
ROUTER C
ip vrf manage
rd 10:1
ip address 10.10.4.1 255.255.255.0
network 10.10.4.0
Jonathan,
08-30-2011 07:04 AM
Thank you.
I might use some other equpment in the network at a later time, so I rather not use EIGRP.
What would you use then?
And how wold the config be with the public range?
08-30-2011 08:34 AM
You don't have to use EIGRP, you can use OSPF or if it is small network, you can use static.
08-30-2011 08:49 AM
Here is a config with OSPF
Router A
ip vrf management
rd 1:1
interface vlan 10
ip vrf forwarding management
interface vlan 20
ip add 192.168.12.1 255.255.255.0
interface vlan 101
description OSPF routing interface
ip add 1.1.2.1 255.255.255.255.252
interface vlan 201
ip add 192.168.2.1 255.255.255.252
router ospf 1 vrf management
network 10.10.2.1 0.0.0.0 area x
network 1.1.2.1 0.0.0.0 area x
router ospf 1
network 192.168.12.1 0.0.0.0 area x
network 192.168.2.1 0.0.0.0 area x
interface gx/x
description connection to Router B
switchport mode trunk
switchport trunk allowed vlan 101,201
Router B
ip vrf management
rd 1:1
interface vlan 30
interface vlan 40
ip add 192.168.13.1 255.255.255.0
interface vlan 101
ip add 1.1.2.2 255.255.255.255.252
interface vlan 103
ip add 1.1.3.2 255.255.255.255.252
interface vlan 201
ip add 192.168.2.2 255.255.255.252
interface vlan 301
ip add 192.168.3.2 255.255.255.252
network 10.10.3.1 0.0.0.0 area x
network 1.1.2.2 0.0.0.0 area x
network 1.1.3.2 0.0.0.0 area x
router ospf 1
network 192.168.13.1 0.0.0.0 area x
network 192.168.2.2 0.0.0.0 area x
network 192.168.3.2 0.0.0.0 area x
interface gx/x
description connection to Router A
interface gx/x
description connection to Router C
switchport trunk allowed vlan 103,301
Router C
ip vrf management
rd 1:1
interface vlan 50
interface vlan 60
ip add 192.168.14.1 255.255.255.0
interface vlan 103
ip add 1.1.3.1 255.255.255.255.252
interface vlan 301
ip add 192.168.3.1 255.255.255.252
network 10.10.4.1 0.0.0.0 area x
network 1.1.3.1 0.0.0.0 area x
router ospf 1
network 192.168.14.1 0.0.0.0 area x
network 192.168.3.1 0.0.0.0 area x
interface gx/x
08-30-2011 05:34 PM
in this case you can either use the example posted by Edison
OR
you can have the management subnet/traffic to be run in its own vrf using GRE tunneling
in this case the tunnel source and destination between routers will be the normal phsycal interface in the 192.168.x.x subnet while the tunnel itself will be under management VRF and runing its own routing such as eigrp or OSPF
in the case you can have two seperate networks
if helpful Rate
08-31-2011 01:12 AM
I see that you make 2 link subnets, one for the management net and one for the public net.
(VLAN101/201 for router A)
Do I need this because of VRF, seperate link nets for each VRF?
For the public IP ranges, should I use public IPs also for the link nets, or does this not matter?
08-31-2011 06:11 AM
On a typical L3 routing on a switch, if you have 2 subnets - you need to create two L3 Vlans. This has nothing to do with VRF.
If you have public IPs, just replace the IPs you posted with your public ones.
08-31-2011 06:38 AM
- "On a typical L3 routing on a switch, if you have 2 subnets - you need to create two L3 Vlans. This has nothing to do with VRF"
Yes but VLAN 101 and 201 are linknets between Router A and Router B right?
Normally one would just need noe linknet here, but I guess when using VRF seperating the routing tables, you need one for each VRF?
- "If you have public IPs, just replace the IPs you posted with your public ones."
When creating a linknet for the public ranges, should I use public IPs for the linknet also, or can I just use private IP ranges (192.168.x.x/10.x.x.x) here to save some IP addresses?
08-31-2011 10:03 AM
Correct, you need to create 2 Vlans for OSPF adjancencies as you are running 2 different routing tables.
You can use private or public, it is your choice. Be careful with using public ones, if you don't own the public IP address pool and someone is already using that pool in the internet, your hosts won't be able to access those services.
We often recommend customers if they want to use public IP addressing in their internal network, they must own it.
