Help with slow connection link
ashleywilbanks
Well for the past few months I have had terrible bandwidth problems to one of our remote sites. We have a main campus and two remote campuses. Well each site has a CISCO 1720 router. The two remote sites connect back to the main site through these routers via a fractional T1 (frame relay) connection. Well I have noticed that when the connection drops to a crawl between the sites a simple reboot of one of the routers, doesn't matter which, usually fixes the problem. I will post whatever info I need, I just need some help figuring this one out. Thanks.
the fact that the problem solves itself when the router is reboot suggests that the fault might be local, rather than with the Frame Relay line. Can you post the output of 'show version', as wll as the output of 'show interface' (of the relevant frame relay interface) ?
GP
stcjefferson#sho ver
IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(13)T1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 03-Jan-03 20:03 by ccai
Image text-base: 0x80008120, data-base: 0x80822C1C
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
stcjefferson uptime is 2 hours, 12 minutes
System returned to ROM by reload
System image file is "flash:c1700-y-mz.122-13.T1.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 19661K/13107K bytes of memory.
Processor board ID FOC064902QG (3056378915), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
WIC T1-DSU
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
stcjefferson#show int
FastEthernet0 is up, line protocol is up
Hardware is PQUICC_FEC, address is 000b.462d.6819 (bia 000b.462d.6819)
Internet address is 10.16.0.1/16
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 2/255, rxload 1/255
Keepalive set (10 sec)
Half-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:01, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 50000 bits/sec, 61 packets/sec
5 minute output rate 888000 bits/sec, 94 packets/sec
300463 packets input, 26716617 bytes
Received 2979 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
450142 packets output, 602467697 bytes, 0 underruns
300 output errors, 117 collisions, 301 interface resets
0 babbles, 299 late collision, 151 deferred
1 lost carrier, 0 no carrier
Serial0 is up, line protocol is up
Hardware is PQUICC with Fractional T1 CSU/DSU
Internet address is 172.16.0.2/24
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 7/255, rxload 148/255
Encapsulation FRAME-RELAY, loopback not set
LMI enq sent 800, LMI stat recvd 806, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 1023 LMI type is CISCO frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 423/0, interface broadcasts 290
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 02:13:32
5 minute input rate 894000 bits/sec, 96 packets/sec
5 minute output rate 43000 bits/sec, 62 packets/sec
451289 packets input, 598483187 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
67 input errors, 61 CRC, 5 frame, 0 overrun, 0 ignored, 1 abort
299425 packets output, 23529468 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
1 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
From the show interface o/p i sense that you are having around 894K traffic ,can you justify the authenticity or the kinda traffic in your network ?
is it supposed to handle this much traffic or let me put it in the other way do u really have this much traffic in your network between your locations ?
i guess it mite be some unwanted worm or virus traffic if u dont have much traffic in place between your locations..
Also the droppage u meant did u try to ping it up when theres some issue and also it does show some input and CRC errors in ur serial link .suggest to get that checked tooo to avoid the probablities involved in troubleshooting your probs..
regds
Well it does appear to slow down during the time a certain class comes to use one of the labs. They use some Internet based instructional software while they are in plus the normal faculty/staff checking email, surfing the web, using more online software. But, after rebooting the router everything works fine (even while they are working) until the next day. also when pinging the router or a any particular device on that network during peek hours I get no response or very slow like 400ms response time. But like I said a simple reboot and everything runs fine again.
