HELP with WCCP and Riverbed on 6509 and 4500X
carl_townshend
Hi All
We are having a real pain getting riverbed to work in our environment.
The setup is as follows
HQ
6509 running VSS, Version 12.2(33)SXI4a
Servers based here on vlan 691
wan connected to vlan 100
we have a redirect 61 in on the wan vlan
and a redirect 62 in on the server vlan
at the other site
We have a 4500X switch running VSS, Version 03.06.05.E
redirect from client vlan 200 in
and redirect 62 in from the wan vlan 300
Riverbed at each end of the link running wccp.
For some reason as soon as we put the traffic redirect commands on both switches on each site, the users can no longer access the application, it is if the traffic is being black holed.
The Riverbeds do see the connections but the users cannot access.
Any ideas why this is not working?
cheers
7 Replies 7
GRANT3779
Hi Carl,
Been a while since I have touched riverbeds.
Do you have other traffic going through these Steelheads or is this the first time putting traffic through them?
Do you have a high level diagram of the cabled connections from the Riverbed to switch and the cisco side config. Are you seeing the application traffic getting across the WAN to the application in the connections?
Hi there
no other traffic going through other than that redirected via the wccp access lists from both sides.
we just have 1 physical inpath connection on both steelheads with wccp redirecting to this and 1 management connection to each.
I was seeing some connections on the riverbeds but they cannot access the application
Does the app work with the optimization service stopped?
If I stop the service, it then starts working again
But it looks like this effectively switches off the WCCP
any ideas ?
Out of interest what is the application that doesn't work when going through the Riverbeds?
its Siemens nx teamcentre used for CAD
What do you have setup regarding inpath rules?
Were these Steelheads put in specifically for this app?
Might be worth running pcap direct from the steelheads at each end and have a look in Wireshark, or the logs within.
