VPN routing
MarkMark58076
Hello All.
I have an ASA 5506 and i have 2 problems with my VPN.
1- when i make a split tunnel it works and i get access to the internet but i can't access my local network.
2- if im not using a split tunnel i can access my local network except one Subnet  For example:
Servers Subnet:172.16.11.0/24
CCTV Subnet:172.16.18.0/24
i can access the Servers Subnet but i can't do the same with CCTV Subnet.
Can anyone help me with this??
Thanks in advance.
rishrapsody1
Can you please share the config of your ASA
Alan Ng'ethe
Level 3
Level 3
Create a split tunnel that includes only the networks you wish to access. The access list referenced by the split tunnel command should encompass both subnets 172.16.11.0/24 and 172.16.18.0/24. Ensure the subnets are reachable from the ASA.
ciscoasa(config)#access-list Split_Tunnel_List remark The corporate network behind the ASA.
ciscoasa(config)#access-list Split_Tunnel_List standard permit 10.0.1.0 255.255.255.0
ciscoasa(config)#group-policy hillvalleyvpn attributes
ciscoasa(config-group-policy)#
ciscoasa(config-group-policy)#split-tunnel-policy tunnelspecified
ciscoasa(config-group-policy)#split-tunnel-network-list value Split_Tunnel_List
ciscoasa(config-tunnel-ipsec)# default-group-policy hillvalleyvpn general-attributes
ASA/PIX: Allow Split Tunneling for VPN Clients on the ASA Configuration Example
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
