Help
korbenda11as
I am about to do a password recovery with my cisco 2800 series router, however, instead of command confreg 0x2142, I accidentally command confreg 0x2124. What should I do next? After I command "reset" it shows strange characters instead of the "#" sign. Pls. help. thanks...
Laurent Aubert
This link will help you:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml
0x2124 change the speed of console port to 19200 instead of 9600.
Laurent.
Laurent Aubert
Laurent.
thanks a million! it works!
You're welcome !!
Laurent.
