Help
pleasantbill
My daughter gave me an older wireless router she had in the closet.I hooked it up to my cable for my pc and that all went well.She does not remember the password. How do I change it so my grandchildren can use their notebooks when they are visiting?
Thank You
Bill Pleasant
Hello Bill,
the factory default settings are:
Username: admin (or no username)
Password: admin
IP Address: 192.168.1.1
SSID: CiscoXXXXX
Try those, chances are they have not been altered.
Otherwise, reset the device to factory defaults:
3. How do I reset the Linksys E2500 to factory defaults?
http://www.linksys.com/ca/support-article?articleNum=137174#H3
Bill,
what model/type is the router ? Usually there is a way to reset a device to factory defaults...
E2500 Linksys.
Hello Bill,
Password: admin
SSID: CiscoXXXXX
pleasantbill
That did it. Thank You.........
