hi have problem with configuration of router 1905
darshankumar.r
i have 1905  with isp reliance connection they have given
1)lan public ip 115.x.x.x/255.255.255.248
2)wan public ip 115.x.x.x/255.255.255.252
router i have 2 interfaces and i have 50 lan user and i have configured s0/0 for another branch,please let me know how should i configure lan public ip with mine lan private ip on the same interface by that both should work.please let me know if any know the configuration.i will be very thank for your suggetion
paolo bevilacqua
Have you considered enaging a reputable consutlant or certified Cisco partner? That would save you many hours of frustration and poor results when trying to do by yourself a task that is for professionals.
ROBERTO TACCON
Level 4
Level 4
Agree with Paolo ... but for knowlegde check the following clear doc:
http://stack.nil.com/ipcorner/SmallSiteMultiHoming/
RCOMcare123
Dear Customer,
We regret the inconvenience caused to you. This is to inform you that your concern has been noted. Please share your contact details such as Full name, Subscriber ID, Mobile no., and the type of Inconvenience you are facing, so that we are able reach you. Our team is eager to help you.
Cheers,
RCOMcare
Not bad.  Not bad at all (+5).  Now that's what I call service!
