hi need help on this cisco 1921 router full, auto & half duplex
AAngelo Wong
we have this old 1841 series router and we change to 1921, i just similarly set the settings same, but only this duplex  thing is having problem (i think).
we are supposedly to have 20mbps up&download speed using this 1841, and if we use 1921 20down/ 10upload speed.
when i set gi0/1 to duplex full it goes down down. but if i set duplex to auto, it register as halfduplex and internet will work but only 10mbps upload. see below
igabitEthernet0/1 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 0000000
  Description: "Connected to Tel"
  Internet address is 000000
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 13/255
  Keepalive set (10 sec)
  Half Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/14/10242 (size/max/drops/flushes); Total output drops: 79729
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 5400000 bits/sec, 546 packets/sec
  5 minute output rate 719000 bits/sec, 390 packets/sec
     170608043 packets input, 1963069286 bytes, 79501 no buffer
     Received 477 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 4 throttles
     0 watchdog, 0 multicast, 0 pause input
     160510262 packets output, 1965851816 bytes, 0 underruns
     0 output errors, 4095435 collisions, 0 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
i appreciate your feedback and thanks a lot
It is very likely that the provider has configured his device for 100 MBit which was compatible with the FE-interface of your 1841. If you configure the 1921 to a fixed speed of 100MBit and full-duplex it should probably work.
thanks a lot. it workssss
