BGP question
m.arancibia
In IOS we have the command bgp deterministic-med , in IOS XR what is the command or commands that perform the same operation?
Regards.
Mario
fzamora
The option is enabled by default
fzamora
Hello.
Would you be able to provide the Cisco reference doc/link for the matter?
Knowing that Juniper already been enabled by default the deterministric-med long time ago, and Cisco recommended to enable it long time ago as well (8-10 years ago), it is reasonable to expect that the deterministic-med enabled by default in the IOS-XR.
Thanks in advance.
Won.
