Cisco router NAT config for inbound access
Herman2018
Level 3
Level 3
Hi, I am tring to config NAT on cisco router for inbound traffic for external users to access our internal web server. The network topology looks like below. ssh from Router2 (192.168.0.2) to server (10.0.0.10), the command is " ssh 1.1.3.3"  it is successful,
but ssh from user PC , ssh 1.1.3.3 from iP 172.16.0.2, then failed, the destination IP is natted to 10.0.0.10, but no return traffic. From server, there is route to user PC. Can someone please advise, thanks in advance.
NAT config on Router1:
ip nat inside source static 10.0.0.10 1.1.3.3
int g0/0
ip nat outside
int g0/1
ip nat inside
6 Replies 6
Because the server not use ssh port 22 it use other port.
Check this point.
MHM
Thanks @MHM Cisco World  for your advice. However, the server is listening on port 22. Can ssh to it from Router2.
Ohh
I remember your case
You use ip nat outside source
Or
Ip nat inside source
What is interface in router1NAT inside and outside
MHM
I have told which interface is inside and outside, please see the above.
I see
ip nat outside source static  1.1.3.3 10.0.0.10
Points to check
1- Router1 and Router2 must know the 10.0.0.0 i.e. there is prefix in it RIB
2- CE server must know 172.16.0.0 PC subnet i.e. it in RIB
MHM
Now the
Hello
The CFG looks correct, as from R2 is reaches the internal server , which suggests from the NAT rtr 1, the 192.168.0.0 network is reachable but 172.16.0./24 network  isnt
Kind Regards
Paul
