04-13-2017 01:59 PM - edited 03-05-2019 08:21 AM
As long as I remember, there is an SNMP object used to hide IP SLA configuration from the running configuration file. Recently, I tried to find the OID but I'm having difficulties finding anything relevant. Can anybody provide me with the OID(s) and a documentation if possible.
Thanks.
04-13-2017 11:17 PM
the only thing I can think of is configuring an snmp server view that restricts access to the IP SLA Mib(s).
snmp-server view noipsla oid-tree excluded
where the oid-tree would be the one of the IP SLA Mib you want to restrict access to.
Is that what you are referring to ?
04-14-2017 12:18 AM
Hers another way ,see the screenshot I have attached , I couldn't print it as CSC forum blocks the brackets , this EEM script should block it , I use it to block menus in my config that have up to 300 lines of config , when the show run initiates EEM kicks in and tells it to exclude the sla config
you can see it with show event manager history events ... after it runs
or if you need to remove it just no event manager .....
One thing il say I hit a bug with this in ios-xe 16.04b image but only on about 5 out of 70 routers , it would just abort and hang , you can test anyway if you want
