Hierarchal QoS policy and Priority vs Bandwidth command and testing with IPerf
I am testing some QoS policy configurations on two Cisco 1841 routers.
In the real world one side of this would terminate on a 10Gbps NNI interface on an ASR9001 as an 802.1q tagged sub-interface, and the other on a C1111-4P with a 100Mbps WAN termination.  This particular setup also has Q-in-Q with two inner VLAN tags to provide two VRFs.  One is limited to 70Mbps and the other 30Mbps.  The 30Mbps needs to be further split to provide a guaranteed 10Mbps to VoIP and 20Mbps to everything else.
I have therefore stripped this back to two 1841 routers connected back to back with an Ethernet X-over cable on their FE0/0 interfaces.  I have created a parent policy that shapes the traffic to 30Mbps with a child policy to provide a LLQ of 10Mbps for a voice class and class-default with 20Mbps bandwidth.  I am using an ACL to match traffic for the voice class so I can simulate voice and non-voice traffic.
I have a laptop either side connected to a switchport and am using IPerf3 to generate traffic.
The qos configuration on both routers is this:
ip access-list extended qos-acl
 permit tcp any any eq 65001
 permit tcp any eq 65001 any
class-map match-any VOICE-CLASS
 match access-group name qos-acl
policy-map POLICY-QOS-CHILD-POLICY-30MB
 class VOICE-CLASS
  priority 10000
 class class-default
  set dscp default
  bandwidth 20000
policy-map POLICY-QOS-OUT-30M
 class class-default
  shape average 30000000
   service-policy POLICY-QOS-CHILD-POLICY-30MB
interface FastEthernet0/0
 ip address 10.10.10.1 255.255.255.254
 duplex auto
 speed auto
 service-policy output POLICY-QOS-OUT-30M
On one side I have a PC running IPerf3 in server mode in two separate command prompt sessions - one listening on TCP/65001 (VoIP)  and the other on TCP/65002.
On the other side I run IPerf3 in client mode and connect to the server on either TCP/65001 or TCP/65002.  If I run a single session to either TCP port it goes up to around 30Mbps.  If I run both sessions simultaneously I see around 6Mbps for the traffic simulating VoIP and around 23Mbps for the other (6.05Mbps & 23Mbps).
If I change the policy so that the VoIP class has a 'bandwidth' statement rather than a 'priority' statement then I see roughly a 10Mbps/20Mbps split (10.2Mbps & 19.3Mbps).
I know the priority command operates differently than the bandwidth command, however I was expecting to see a 10/20 split with both configurations?  The leaky bucket thing always confuses me...
Is this a result of IPerf3 and TCP?
Giuseppe Larosa
Hello @andrew.butterworth ,
your results are interesting:
First of all, real VOIP traffic is UDP based so it does not suffer  TCP windowing effects.
The LLQ queue can have an implicit policer to avoid starvation of standard queues and in your case the effects of this policer is to reduce the goodput of the "VOIP traffic" probably for some drops happening during the test.
When you use the bandwidth commands for both traffic classes you get different results as here with bandwidth there is no implicit policer involved.
What is interesting is that your tests demonstrate the presence of this implicit policer at least on your devices under tests.
Hope to help
Giuseppe
Ditto.
It's not uncommon Cisco policers, using defaults for Tc/Bc, often cause TCP flows to have a lower effective CIR than what's configured. Basically, the impact it much like an interface with a FIFO queue insufficient for TCP's BDP (bandwidth delay product) needs.
