Hierarchical QOS policy on 10720
ianwarb
I have been recently trying to create a hierarchical MQC policy on a 10720 (12.0(28)S2) in order to configure a priority queue for voice traffic. However when I attempt to embed the EF_traffic policy map within the CLASS-DEF class I get the error message ?POLICY- must have only one class to be used a nested policy?. Config below
policy-map POLICY-CE-TO-PE
class CLASS-DEF
shape percent 4
police 37952000 7116000 14232000 conform-action transmit exceed-action transmit violate-action drop
Service-policy EF_traffic
< POLICY- must have only one class to be used a nested policy>
policy-map EF_traffic
class EF_traffic
priority
police 2048000 384000 384000 conform-action set-dscp-transmit 46 exceed-action drop violate-action drop
the idea of a nested policy is to use one policy to shape it down to a desired rate. QoS wise this is like creating a "logical interface" with the specified bandwidth.
All other QoS related actions should be placed in the second policy-map applied to that shaper, i.e. to the "logical QoS interface". So your priority queue should be part of the second policy like in the example given above. You still could use other classes and CBWFQ within the second policy-map.
Hope this helps! Please rate all posts.
Regards, Martin
mheusinger
Level 10
Level 10
there is always the hidden class-map class-default. Can you try out
class class-default
shape percent 4
service-policy (output?) EF_traffic
class EF_traffic
priority
May I ask, what the nested policy should achieve, which is not possible with a single policy?
Regards, Martin
ianwarb
Hi Martin, thanks for the update. I was initially trying this policy as the router in question already had a policing/shaping service-policy on there to throttle the bandwidth. I want to hive off 2Mb of this for priority queuing so thought it would be best to embed it within the existing one
regards
Ian
Regards, Martin
