Hierarchical Qos?
petrk
do you think this can work?
class-map match-all CUSTOMER1
match access-group name cust1
class-map match-all CUSTOMER2
match access-group name cust2
class-map match-any CUSTOMER3
match access-group name cust3
class-map match-any CUSTOMER4
match access-group name cust4
policy-map Shaping
class CUSTOMER1
shape average 128000
class CUSTOMER2
shape average 192000
class CUSTOMER3
shape average 256000
class CUSTOMER4
shape average 512000
class class-deafult
policy-map LMQOS
class voice
set ip dscp ef
class High
set ip dscp af32
bandwidth 2048
service-policy Shaping
class Low
set ip dscp af31
bandwidth 2048
class best-effort
set ip dscp default
ip access-list extended cust1
permit ip 1.1.1.0 0.0.0.255 10.10.10.0 0.0.0.255
ip access-list extended cust2
permit ip 2.2.2.0 0.0.0.255 10.10.10.0 0.0.0.255
ip access-list extended cust3
permit ip 3.3.3.0 0.0.0.255 10.10.10.0 0.0.0.255
ip access-list extended cust4
permit ip 4.4.4/0 0.0.0.255 10.10.10.0 0.0.0.255
The goal is to shape specific traffic in each class and also perform queing.
Or is there any better (working) way to achieve this?
peter
I can understand that concern. The problem, though, is when you apply a 128k shaper to the 3 different classes of service you've specified, they will operate independantly. So in theory, you'll be shaping at 384k to that destination.
The way i've proposed actually will attempt to preserve the traffic classes. A single LLQ will be made from all different LLQ classes in order to preserve that traffic (up to line rate, or configured "priority" values). Also, when the interface is under congestion, it will begin dequeueing at a lower rate from the shaping queues, but the shaping queues will still give priority to the classes you've put a bandwidth guarantee on.
mmorris11
Level 4
Level 4
It should work but it looks like you still have some classes to define; voice, high, low and best-effort
-mike pls rate if helpful
wochanda
Level 4
Level 4
From the look of your config, it looks like you've got a "CIR" on a per-location basis, so you want to use shaping to not exceed that value. You also want to do QoS to preserve different classes on a per-site basis. If so, you're close, but you applied the policy-maps backwards. I think this is what you were going for:
policy-map Shaping
class CUSTOMER1
service-policy LMQOS
class CUSTOMER2
class CUSTOMER3
class CUSTOMER4
policy-map LMQOS
class voice
set ip dscp ef
priority percent 20
class High
set ip dscp af32
bandwidth percent 15
class Low
set ip dscp af31
bandwidth percent 10
class best-effort
set ip dscp default
Since we're applying the same policy to different speed classes, I went ahead and modified your QOS to guarantee based on percentage, rather than absolute values. This way you wont need independant per-site policy-maps.
And, much like the other comment in this thread, you may want to guarantee bandwidth for voice, and create a LLQ by using the "priority" command under voice. I went ahead and modified your config to contain this.
Thanks for reply. I applied policy-map backward because I want first sort the packets in a correct order and then shape this flow. That means packets with highest priority will not be dropped.
