main iface vs. sub-iface
petrk
what is the difference between applying policy-map on main interface or sub-interface? We are using frame relay encapsulation with several PVCs.
gpulos
Level 8
Level 8
if applied on the subInterfaces, policy-maps can set different properties for different PVCs. (multiple policyMaps for multiple subInterfaces)
if a policyMap is applied at the interface level, the entire interface is considered to use that policyMap.
wochanda
Level 4
Level 4
With frame-relay, the best way to apply service-policies is on the frame-relay shaper.
IE.
map-class frame-relay T1shaper
frame-relay cir 1544000
frame-relay mincir 1544000
frame-relay bc 15440
service-policy output MyPolicy
int s0/0.1 point
frame-relay interface-dlci 201
class T1shaper
Take a look at this doc:
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a008009489a.shtml
