high cpu utilization on 7206VXR
gauravm
hi,
we have 7206VXR Routers as the core Routers .The CPU utilization on these routers is showing 100% most time of the day.im attaching the sh processes cpu history output .
kindly let me know is there a problem or is it a normal behavoiur .also let me know how to rectify it as its our core router.
1 1 1 111111111111 1 1 1 1 1 11 1 11 111111
20911110 80 0000000000009 221332 107020809881070090 005 210000009
8090100084070000000000009934810985030805089340800807979680079800000000
100 ** * * ************* * * * ** * **** ** ****** **
90 ** * * ************* * * ***** * **** ** *********
80 ** * ** ************* * * ****** ****** ** *********
70 ** * ** ************* *** ****** ****** ** *********
60 ** * ** ************* *** ****** ****** *** *********
50 ** * ** ************* *** ****** ****** *** *********
40 ** * ** ************* *** ****** ****** *** *********
30 *** * ** ************* *** ********** ****** *** * *********
20 *** * ** ************* ****** *********** ****** *** * *********
10 ****************#########***********#***#########****************#######
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
* = maximum CPU% # = average CPU%
rabeder
hi,
this is NOT a normal behavoiur !
first you have to troubleshoot which process is responsible for that cpu-load:
do a "sh proc cp sort" - so you can see which proceß has the most cpu-cycles.
is "cef" enabeld ?
you can check this by doing a "sh ip cef"!
pls try
hi,
thanks for the response.
cef is not enabled in network.
following is the outut of the sh proce cpu sort
32 9803280 2260666 4336 0.55% 0.45% 0.44% 0 Per-Second Jobs
50 3414016 83988891 40 0.23% 0.27% 0.25% 0 IP Input
kindly help ...to resolve.
It seems that it is your utilisation is spiking as the average utlisation is still low. This is because from your graph, you have asterixs(*) and not hash(#).
I will advice you to give the sh proc cpu sorted 5sec comamnd repeated, until you capture an utilisation that is high and you can then see the highest utilisation then. That will point you in the direction for the reslution.
You could enable CEF, but since I doubt that the problem is due to traffic, I doubt that it will solve it.
There's a number of troubleshooting documents on CCO that look should help to track down the cause.
Troubleshooting High CPU Utilization on Cisco Routers
http://www.cisco.com/en/US/partner/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
Troubleshooting High CPU Utilization Due to Interrupts
http://www.cisco.com/en/US/partner/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
Troubleshooting High CPU Utilization due to Processes
http://www.cisco.com/en/US/partner/products/hw/routers/ps359/products_tech_note09186a00801c2af6.shtml
Steve
