High CPU Utilization Router 2801 - Interrupts
Wellington L
I have problems with router 2801, the version is
Cisco IOS Software, 2801 Software (C2801-ADVENTERPRISEK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
When i start a download the processes of the router cpu stay in 99%/97%.
When i'm not doing a download the processes stay in 3%/0%.
I have one 20 mb link to Wan.
I did the troubleshooting seeing the this document :
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
But this document, isn't clear to me about how i will do to resolve this problem.
8 Replies 8
   Have you applied the following features on your router?
- Policy Based Routing. This can cause when downloading.
- Police commands (Qos). This can cause when downloading.
- Too many dynamic nat entries. This can cause when downloading.
High CPU Interrupts actually happens when process-switch getting involved.  The document you provided I used to read it once. But it's not my favorite document. (grin)
HTH,
Toshi
Yes, these features have in the router.
In relationship the process switching, before this happened the IP INPUT was in 60% but i did the troubleshooting and the outside interface wasn't ip route cache habilitated.
When I habilitated this, the IP INPUT stays in 0.05% but the process in  the CPU when i start the download continue in 99%/97%.
I thins is interrupt processes but i need to know about how i will do to resolve this problem.
I was thinking be the IP INPUT, but wasn't it.
I need to know too, if this router (2801) supports a 20 Mb WAN link, because before this situation i had a 12 MB WAN Link and did't have problems, and when i put 20 mb WAN Link the problems starting.
Case it is true, I need a documment to comprove this situation.
Thank You..
Wellington L
Only to supplement,
I read this doccument about the Router 2801, and it says about the 2801 supports 46 Mb Link no sevices enabled.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
But in my router i have 20 Mb Wan Link and ACL, NAT, Call Manager, VPN.....
In the processes when i start the download it goes to 99%/97%.
How will i do to resolve this problem ?
Version :
System image file is "flash:c2801-adventerprisek9-mz.124-24.T4.bin"
Cisco 2801 (revision 7.0) with 240640K/21504K bytes of memory.
Processor board ID FTX1144Y077
2 FastEthernet interfaces
31 Serial interfaces
1 Channelized/Clear E1/PRI port
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
2 Voice FXS interfaces
6 DSPs, 96 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
127488K bytes of ATA CompactFlash (Read/Write)
CPU Processes :
CPU utilization for five seconds: 99%/97%; one minute: 91%; five minutes: 76%
  2       40256      604148         66  0.39%  1.10%  0.60%   0 Load Meter
  18      384696     1377668        279  0.07%  0.01%  0.00%   0 ARP Input
  41       32220     3021005         10  0.07%  0.03%  0.02%   0 Per-Second Jobs
  49       37796      604358         62  0.08%  0.04%  0.03%   0 Compute load avg
  50     1653896       51303      32237  0.00%  0.02%  0.04%   0 Per-minute Jobs
101    77899544    21743281       3582  0.30%  0.43%  0.40%   0 IP Input
108     4607320    12685643        363  0.30%  0.41%  0.39%   0 Skinny Msg Serve
163      169636   106584017          1  0.07%  0.13%  0.19%   0 HQF Shaper Backg
149       39492     4398679          8  0.07%  0.04%  0.06%   0 CEF: IPv4 proces
343       43060        1050      41009  0.89%  0.33%  0.24% 197 Virtual Exec
Interfaces :
FastEthernet0/1 is up, line protocol is up
Description:  internet
Internet address is xxx.xxx.xxx/20
MTU 1500 bytes, BW 20000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 3/255, rxload 142/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:05, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:46:56
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 11182000 bits/sec, 1074 packets/sec
30 second output rate 253000 bits/sec, 548 packets/sec
2916486 packets input, 3875038809 bytes
Received 546 broadcasts, 0 runts, 0 giants, 0 throttles
21 input errors, 0 CRC, 0 frame, 0 overrun, 21 ignored
0 watchdog
1527008 packets output, 96470325 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
Thank You.
     Cisco always say that the router can do that without any service. You said that the problem occurs when downloading. Some service has to invoke CPU. Well ,11Mbps can cause the problem. Please post your configuration,excluding sensitive information.
HTH,
Toshi
Follow the configuration
   You have got many features on it. What is the mac-address applied on the rate-limit?  Is the counter of this rate-limit being increased while downloading?  How many nat entry when you're downloading?  Just try "show ip nat statistic".
Toshi
The Mac-Address is a machine that i need to use the rate-limit, but is it the cause to do the processes up ?
The out of the nat static when I'm doing a download is this :
Total active translations: 371 (0 static, 371 dynamic; 371 extended)
Peak translations: 1477, occurred 3w1d ago
Outside interfaces:
  FastEthernet0/1
Inside interfaces:
  FastEthernet0/0.1, FastEthernet0/0.5, FastEthernet0/0.6, FastEthernet0/0.10
  FastEthernet0/0.13, VoIP-Null0
Hits: 82566512  Misses: 0
CEF Translated packets: 38132100, CEF Punted packets: 1026623
Expired translations: 1051314
Dynamic mappings:
-- Inside Source
[Id: 8] route-map SDM_RMAP_1 interface FastEthernet0/1 refcount 364
Appl doors: 0
Normal doors: 0
Queued Packets: 0
Thank You.
I need to know if this router can use all processes like vpn, nat, call manager
and other processes with a 20 mb WAN link, becase before this situation i had a 12 mb link and never had problems with
that.
Thank You.
