InterVlan Routing Issue on 6500
martinezaw
Hi All,
This should be real simple, but for some reason it does not work. My 6500 is only allowing me to enable one VLAN interface at a time.
interface Vlan2165
ip address 10.201.BB.30 255.255.255.224
shutdown
interface Vlan3038
ip address 10.201.BB.138 255.255.255.224
interface Vlan3065
description CTX-ROUTER
ip address 10.201.BB.161 255.255.255.240
no ip redirects
ip flow ingress
shutdown
As you can see only interface vlan 3038 is not shutdown. When I try to do the "no shut" command on the other interfaces, nothing happens and the interface still shows administratively down. Is there some special command I need to make sure is in place on the 6500 to make sure that I can have more than one VLAN interface enabled at once??
6513(config)#do sh int vlan3065
Vlan3065 is administratively down, line protocol is down
  Hardware is EtherSVI, address is 000d.662f.4b80 (bia 000d.662f.4b80)
  Description: CTX-ROUTER
  Internet address is 10.201.26.161/28
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 3 interface resets
What IOS are you running?
IOS
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
FYI... It also has a Sup 720 as the sup module.
Thanks...
