High cpu utilization with RIP Router
lvrak2102
Dear All,
I have one 7507 router and 6509 Switch which are running on OSPF and RIP. These days i'm observing high cpu utilzation on these devices. when i check the "show proc cpu sorted" RIP Router is showing 3-4%. My doubt is whether RIP updates will have that much impact on the cpu utilization.
JonathanUK
Level 3
Level 3
Have you read this info before it has some useful links
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
Hope that helps
The problem i'm facing is due to high ip input and rip router.i would like to know whether rip updtes will have impact on the utilizations...just have a look at this attachement
Usually high input problem can be nullified by enabling CEF on the routers.
Is it possible for you to configure IP CEF in global mode and check for any change or difference in the CPU utilisation ??
regds
