high cpu with interrupt at 7304
mishao
hi ,
i found 7304 with high cpu load with high interrupt.
i check the cef and found a lot of Unsupported packets and punt packets.
what do i do next ?
best regards.
fred.
show the below.
CPU utilization for five seconds: 44%/42%; one minute: 40%; five minutes: 38%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 6 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 220 379462 0 0.00% 0.00% 0.00% 0 Load Meter
3 172 2395686 0 0.00% 0.00% 0.00% 0 IP NAT Ager
4 1093224 201449 5426 0.00% 0.02% 0.00% 0 Check heaps
5 0 1 0 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
8 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
9 7028300 1890548 3717 0.47% 0.26% 0.23% 0 EnvMon
nvwtv-7304#show cef drop
Load for five secs: 41%/40%; one minute: 41%; five minutes: 38%
Time source is NTP, 15:08:51.219 TPE Fri May 26 2006
% Command accepted but obsolete, see 'show (ip|ipv6) cef switching statistics [f
eature]'
IPv4 CEF Drop Statistics
Slot Encap_fail Unresolved Unsupported No_route No_adj ChkSum_Err
RP 0 0 146736291 0 18056 0
nvwtv-7304#
nvwtv-7304#show ip cef switching stat
Load for five secs: 38%/37%; one minute: 41%; five minutes: 39%
Time source is NTP, 15:09:19.035 TPE Fri May 26 2006
Path Reason Drop Punt Punt2Host
RP RIB Packet destined for us 0 3964591 0
RP RIB Total 0 3964591 0
RP LES Packet destined for us 0 3553773 0
RP LES Total 0 3553773 0
RP PAS Packet destined for us 0 3553773 0
RP PAS No adjacency 18056 0 8438
RP PAS TTL expired 0 0 69298723
RP PAS IP options set 0 0 1356
RP PAS Features 0 0 77431401
RP PAS Total 18056 3553773 146739918
All Total 18056 11072137 146739918
nvwtv-7304#
spremkumar
Level 9
Level 9
This link talks about Punts and different ios switching methods you can deploy when moving from fastest to slowest switching interface...
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1828/products_tech_note09186a00801e1e46.shtml#punts
regds
