High Latency from LAN
eash
Dear All,
I have one customer there are experiencing high latency from their LAN. When I tried extended ping from the router the latency was 124ms to 144ms. When the customer is pinging from the LAN the latency is 260ms. We the customer disconnected the LAN and connected his laptop directly to the router and checked the response is same about 260ms.
Any suggestion on the cause.
The ping responses are as below,
Router#ping
Protocol [ip]:
Target IP address: 172.17.10.1
Repeat count [5]: 100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 172.20.235.240
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 100, 100-byte ICMP Echos to 172.17.10.1, timeout is 2 seconds:
Packet sent with a source address of 172.20.235.240
Success rate is 100 percent (100/100), round-trip min/avg/max = 124/125/136 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 128/130/132 ms
Router#ping
Protocol [ip]:
Target IP address: 172.17.240.130
Sending 100, 100-byte ICMP Echos to 172.17.240.130, timeout is 2 seconds:
Success rate is 97 percent (97/100), round-trip min/avg/max = 136/141/152 ms
Router#ping
Protocol [ip]:
Target IP address: 172.17.244.72
Sending 100, 100-byte ICMP Echos to 172.17.244.72, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 144/148/164 ms
C:\Users\DKSPL003>ping 172.17.10.1
Pinging 172.17.10.1 with 32 bytes of data:
Reply from 172.17.10.1: bytes=32 time=260ms TTL=248
Reply from 172.17.10.1: bytes=32 time=259ms TTL=248
Ping statistics for 172.17.10.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 259ms, Maximum = 260ms, Average = 259ms
C:\Users\DKSPL003>tracert 172.17.10.1
Tracing route to ns.sys.mmc.co.jp [172.17.10.1]
over a maximum of 30 hops:
  1     1 ms    <1 ms    <1 ms  172.20.235.240
 2   260 ms   260 ms   259 ms  172.17.28.25
  3   260 ms   260 ms   260 ms  172.17.1.250
  4   260 ms   260 ms   260 ms  172.17.27.241
  5   259 ms   259 ms   259 ms  ns.sys.mmc.co.jp [172.17.10.1]
  6   260 ms   259 ms   259 ms  ns.sys.mmc.co.jp [172.17.10.1]
  7   260 ms   260 ms   261 ms  172.17.27.162
  8   261 ms   260 ms   261 ms  ns.sys.mmc.co.jp [172.17.10.1]
Trace complete.
C:\Users\DKSPL003>tracert 172.17.244.72
Tracing route to 172.17.244.72 over a maximum of 30 hops
  1     1 ms     1 ms    <1 ms  172.20.235.240
  2   261 ms   260 ms   260 ms  172.17.28.25
  3   260 ms   259 ms   268 ms  172.17.2.240
  4  1468 ms   264 ms   264 ms  172.16.1.6
  5     *      272 ms   270 ms  172.16.2.2
  6   275 ms   275 ms   274 ms  172.16.2.1
  7   275 ms   275 ms   275 ms  172.17.240.241
  8   275 ms   275 ms   275 ms  172.17.243.241
  9   285 ms   283 ms   282 ms  192.168.244.1
10   283 ms   283 ms   283 ms  172.17.244.72
Trace complete.
C:\Users\DKSPL003>ping 172.17.244.72
Pinging 172.17.244.72 with 32 bytes of data:
Reply from 172.17.244.72: bytes=32 time=282ms TTL=119
Reply from 172.17.244.72: bytes=32 time=283ms TTL=119
Reply from 172.17.244.72: bytes=32 time=285ms TTL=119
Reply from 172.17.244.72: bytes=32 time=294ms TTL=119
Ping statistics for 172.17.244.72:
    Minimum = 282ms, Maximum = 294ms, Average = 286ms
C:\Users\DKSPL003>
Eash
eash
Dear All,
Any feedback on the above problem.
Eash
I also see a few drop in the ping test.
Look for a point of congestion.
Hi Joseph,
The checked the config in the router the customer has configured IPSec and GRE tunnels.
Request you to kindly check the config and let me know if the MTU setting are correct.
Current configuration : 5259 bytes
! No configuration change since last restart
version 12.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
logging buffered 16384 informational
logging monitor informational
enable secret 5
no aaa new-model
dot11 syslog
no ip icmp rate-limit unreachable DF
ip cef
no ip domain lookup
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key MMCG-VPN_Etype address X.X.X.X no-xauth
crypto isakmp key MMCG-VPN_Etype address Y.Y.Y.Y no-xauth
crypto isakmp keepalive 10 6 periodic
crypto ipsec transform-set DEFAULT esp-3des esp-md5-hmac
crypto map VPN_M 1 ipsec-isakmp
 set peer X.X.X.X
 set transform-set DEFAULT
 match address VPN_List(NC#4-1)
crypto map VPN_M 11 ipsec-isakmp
 set peer Y.Y.Y.Y
 match address VPN_List(B_NC#1)
archive
 log config
  hidekeys
ip telnet source-interface Loopback255
interface Loopback252
 description *** for GRE#1 ***
 ip address 172.20.252.173 255.255.255.252
interface Loopback253
 description *** for GRE#2 ***
 ip address 172.20.253.173 255.255.255.252
interface Loopback254
 description *** VoIP Source_Address <Spare> ***
 ip address 172.20.254.173 255.255.255.252
 description *** Telnet Source_Address ***
 ip address 172.20.255.173 255.255.255.252
interface Tunnel1001
 description *** NC_GRE#1 ***
 bandwidth 5000
 ip unnumbered Loopback252
 ip mtu 1366
 ip hello-interval eigrp 100 10
 ip hold-time eigrp 100 40
 delay 1000
 keepalive 10 4
 traffic-shape rate 5000000 125000 125000 1000
 tunnel source Loopback252
 tunnel destination 172.17.28.25
 crypto map VPN_M
interface Tunnel1011
 description *** to B_NC_GRE ***
 bandwidth 5000
 ip mtu 1366
 delay 3000
 keepalive 10 4
 tunnel destination 172.17.241.129
 crypto map VPN_M
interface FastEthernet0/0
 description LAN
 bandwidth 100000
 ip address 172.20.235.240 255.255.255.0
 ip helper-address 172.17.10.22
 ip helper-address 172.17.10.23
 ip route-cache policy
 ip tcp adjust-mss 1326
 ip policy route-map Ether-Prec
 speed 100
 full-duplex
 no cdp enable
interface FastEthernet0/1
 description  *** new link ***
 bandwidth 1000000
 ip address  a.b.c.d 255.255.255.252
 ip access-group Filter_List(IN) in
 ip mtu 1400
 duplex full
 speed 100
 no cdp enable
 crypto map VPN_M
interface Serial0/0/0
 no ip address
 shutdown
 clock rate 2000000
router eigrp 100
 passive-interface default
 no passive-interface Tunnel1001
 no passive-interface Tunnel1011
 network 172.20.0.0
 default-metric 10000 100 255 1 1500
 distribute-list prefix LAN out Tunnel1001
 distribute-list prefix LAN out Tunnel1011
 no auto-summary
ip local policy route-map Precedence
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 e.f.g.h
ip route 172.17.28.24 255.255.255.252 FastEthernet0/1 e.f.g.h name NC#4-1
ip route 172.17.241.128 255.255.255.224 FastEthernet0/1 e.f.g.h  name B_NC#1
no ip http server
no ip http secure-server
ip access-list extended Filter_List(IN)
 permit udp any eq isakmp any eq isakmp
 permit esp any any
 permit icmp any any echo
 permit icmp any any echo-reply
ip access-list extended VPN_List(B_NC#1)
 permit gre host 172.20.252.173 host 172.17.241.129
ip access-list extended VPN_List(NC#4-1)
 permit gre host 172.20.252.173 host 172.17.28.25
ip prefix-list LAN seq 5 permit 172.20.235.0/24
ip prefix-list LAN seq 10 permit 172.20.252.0/24 ge 30 le 30
ip prefix-list LAN seq 15 permit 172.20.253.0/24 ge 30 le 30
ip prefix-list LAN seq 20 permit 172.20.254.0/24 ge 30 le 30
ip prefix-list LAN seq 25 permit 172.20.255.0/24 ge 30 le 30
access-list 1 remark ***VTY***
access-list 1 permit 172.0.0.0 0.255.255.255
access-list 105 permit tcp any eq telnet any
access-list 105 permit tcp any any eq telnet
access-list 120 permit ip any any precedence immediate
access-list 121 permit ip any any precedence priority
access-list 122 permit ip any any precedence routine
dialer-list 1 protocol ip permit
snmp-server community white RO
snmp-server community black RW
snmp-server trap-source FastEthernet0/0
snmp-server packetsize 2048
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host 172.17.14.1 white  snmp
no cdp run
route-map local-prec permit 11
 match ip address 105
 set ip precedence priority
route-map ether-prec1 permit 10
control-plane
line con 0
 exec-timeout 5 0
 password 7
 logging synchronous
 login
line aux 0
line vty 0 4
 access-class 1 in
 exec-timeout 5 0
 password 7
 logging synchronous
 login
scheduler allocate 20000 1000
ntp clock-period 17178322
ntp source FastEthernet0/0
ntp server 172.17.5.240
end
Easwar
If your end-points support it, you might consider using VTI tunnels.
Your f0/1 tunnel has a MTU of 1400.  If it's the outside facing interface, why isn't set to 1500?
Your tunnel IP MTU of 1366 is a bit odd.  Cisco, I recall recommends they be set to 1400.  mss-adjust is 40 less then your tunnel MTU, which is fine, but it should be set on the tunnel interface, not f0/0.
Not withstanding the foregoing comments, why you have, I believe should work and I don't see it causing an issue, i.e. it's perhaps just sub-optimal.
How's ping performance between physical interface, outside the tunnel?
