High MTU on Tunnel interface
All of the tunnel on our router has high value on MTU (17000++ bytes).
Here is one of the tunnel:
sh int Tunnel65:
Tunnel65 is up, line protocol is up
  Hardware is Tunnel
  Description: ipsec vti to sgsineqnix-gw-2
  Internet address is 10.255.255.66/30
  MTU 17878 bytes, BW 100 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 255/255, rxload 255/255
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 116.214.1.5, destination 116.214.2.5
  Tunnel protocol/transport IPSEC/IP
  Tunnel TTL 255
  Tunnel transport MTU 1438 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "ipsec-vti")
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 2w3d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 57294
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 1035000 bits/sec, 197 packets/sec
  5 minute output rate 301000 bits/sec, 179 packets/sec
     126621059 packets input, 3951039179 bytes, 0 no buffer
     Received 0 broadcasts (329227 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     107858419 packets output, 3543811088 bytes, 0 underruns
     0 unknown protocol drops
sh run int Tunnel65:
interface Tunnel65
description ipsec vti to blah-blah
ip address 10.255.255.66 255.255.255.252
ip summary-address eigrp 89 10.63.0.0 255.255.224.0
tunnel source 116.214.1.5
tunnel mode ipsec ipv4
tunnel destination 116.214.2.5
tunnel protection ipsec profile ipsec-vti
end
We are using Cisco 2911 router with IOS Version 15.2(3)T.
Please advise how to fix this.
Jenna
Vinayaka Raman
please check show ip int tun 65 instead of show int tun 65
Regards Vinayak
it is recommended you have 1400 for GRE plus IPsec..
interface Tunnel1
ip mtu 1400
if i am not wrong, you should considering the MTU which is from show ip int tun 1
Router#show run int tun 1
Building configuration...
Current configuration : 494 bytes
interface Tunnel1
bandwidth 1024
ip address 10.13.0.27 255.255.0.0
no ip redirects
ip mtu 1400
ip flow ingress
ip flow egress
ip nhrp authentication 111
ip nhrp map multicast dynamic
ip nhrp map multicast 205.204.2.251
ip nhrp map 10.13.0.1 205.204.2.251
ip nhrp network-id 101
ip nhrp nhs 10.13.0.1
zone-member security inside
load-interval 30
tunnel source GigabitEthernet0
tunnel mode gre multipoint
tunnel key 111
tunnel protection ipsec profile ocbackupvpn shared
end
Router#show int tun 1 | i MTU
  MTU 17912 bytes, BW 1024 Kbit/sec, DLY 50000 usec,
  Tunnel transport MTU 1472 bytes
Router#show ip int tun 1 | i MTU
  MTU is 1400 bytes
Router#
Regards Vinayak
Hi Vinayaka,
Here's the result of "show ip int Tunnel65":
phmnlccent-gw-3#sh ip int Tunnel65
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1438 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.10
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: MCI Check
  Post encapsulation features: IPSEC Post-encap output classification
  IPv4 WCCP Redirect outbound is disabled
  IPv4 WCCP Redirect inbound is disabled
  IPv4 WCCP Redirect exclude is disabled
phmnlccent-gw-3#sh int Tunnel65 | i MTU
phmnlccent-gw-3#sh ip int Tunnel65 | i MTU
  MTU is 1438 bytes
I understand that on "show ip int Tunnel65" it shows 1438 only but the "show int Tunnel65" is giving too high value.
Can you explain what's the reason for this?
Thanks and regards,
Jenna
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You shouldn't need interleaving/fragmentation with a link > half a T1's bandwidth.
Try setting tx-ring-limit to minimal value on all your serial interfaces.
